Spread Axle Bolt Broke - Help!
mister_d
The bolt in the middle seems to have broken. The washer/nut have disappeared. The whole assembly appears to be angled now. I'd like to try to remove the bolt and replace on my own. Can I just remove it without jacking up the trailer or messing anything up? I pulled images off Google for sake of time .. let me know if more are necessary.
Our Adventures
Me '77 DW '78
DD '04 DS '07
Yellowstone + more Trip Report
2011 F150 4x4 Ecoboost 6.5 SCREW 3.73 Max Tow
2011 Lacrosse 296BHS video tour
Hensley Arrow
18 REPLIES 18
opnspaces
Navigator II
Navigator II
Glad you got it repaired. As you found, a trailer place not an RV dealer is the most likely place to find the splined bolt. That nut you posted is a locking nut. There are a few different ways to make a locking nut. Most of them are like you posted where the jam something into the threads to stop them from vibrating loose.
mister_d
None of the camper places around us had the bolt in stock but I found a trailer place (Taylor for any MI people) that had them. I'm not sure of the grade and I was too excited that they had one in stock to remember to ask.
I followed the advice of jacking the trailer up just enough without taking the tires off the ground. My brother inlaw had a driver drill (?) and the bolt came out fairly easy. The threaded end was the part that broke off.. only a couple were left. Things were bent up a bit but I was able to use a c-clamp to pinch it all back together to get the new bolt straight through.
I also followed the advice of tightening the nut and letting it pull the bolt in. The provided nut was indented (? see image) and seemed to be a locking type so I used it instead of a lock nut with the plastic insides (?).
Things look good so hopefully they are and this doesn't happen again. Thanks for everyone's help/advice!
google image
Our Adventures
Me '77 DW '78
DD '04 DS '07
Hensley Arrow
BurbMan
Lowes home centers carry grade 8 hardware, knot sure if they will have he size though. Also try a Napa , Advance, or Auto Zone, they may have somethin that will fit.
If the end of the bolt is missing, measure the total thickness of where the bolt bgoes plus at least 1/2" for the nut and washer. in this application you definitely want a locknut of some sort, usually one with a nylon insert. Bring the old bolt with you to the store to get the right diameter.
Right now the weight of the trailer is supported by the middle hanger and the ones at the other ends of the leaf springs. if you jack up the trailer until the wheels are off the ground, the wheels and axles will be hanging by those bolts and their weight will still have prssure on that bolt. Jack up the trailer to a point hwere the wheels are still on the ground but the weight of the trailer is being held by the jack....youll have to fiddle with the height to find the space where is no weight on hthe bolt.
opnspaces
Navigator II
Navigator II
Jack up the frame until the pressure is relieved from the equalizers (the linkages hooked to the springs on either side of the bolt) Then use a hammer and drift pin or punch to drive the bolt out. Replace with a new splined bolt and drive the head in until it's seated in the hole. Do not turn the bolt head as you will strip the splines. Only turn the nut to tighten or loosen the bolt.
69_Avion
Once you get the tension off of it you will probably have to drive it out with a proper size drift pin. Hopefully, the splines are still holding the bolt from turning. I'll bet that they are. If not, I used to tack them in place. It is an easy fix either way. The splines are there so that the equalizer turns on the bolt and the bolt doesn't turn inside the mount.
Ford F-350 4x4 Diesel
1988 Avion Triple Axle Trailer
1969 Avion C-11 Camper
RamTX
Lynnmor wrote:
There should be splines just behind the bolt head. If the bolt turned and rounded the splines, it will always move and won't stay tight. When installing, you must hold the bolt head while tightening the nut. If the hanger is already rounded out, you may be able to flip the bolt to get good engagement on the opposite side.
I doubt very seriously if they would have a splined bolt like you need. You could get a grade 8 bolt in probably the right size, but not a splined bolt like you need! As others have said, go to a trailer parts store that carries suspension parts.
2005 Dodge 2500 CTD ShortBed Quad Cab
08 Jayco Eagle Superlite 31.5FBHS
Line X
Superglide Hitch
Prodigy Brake Controller
mister_d
All the RV dealers around here are closed on Sundays. I have a Camping World about 15 minutes away - do you think they would have one?
edit:
I asked around on Facebook and think I found a local hardware store that will have one and be open tomorrow.
Our Adventures
Me '77 DW '78
DD '04 DS '07
Hensley Arrow
Dtaylor
subcamper wrote:
Make sure you get the proper grade of bolt (high strength which is grade 8). If you go to a trailer place, you will probably get the correct type. Don't be tempted to go to a Home Depot and use a bolt that fits, it will not be strong enough.
Steve
THIS! If you are not sure what to ask for, take the head of the old one with you. A good hardware or trailer place should have the correct bolt.
Our Travel Blog
2018 Premier 29RKPR
2014 Ford F-150
subcamper
Steve
69_Avion
Good advice above. Most folks would have never caught the problem until they had a major failure. Good job. The nice part is that it is an easy fix and any local trailer supply should have the correct splined) bolt.
Lynnmor
Huntindog
It's likely from turning tight. Spread axles are great in that it allows for a lighter frame, more stable towing and lighter TV. The tradeoff is what you now have. There is more stress on the components when turning.
There is no free lunch. Improve one area at the expense of another.
Huntindog
100% boondocking
2021 Grand Design Momentum 398M
2 bathrooms, no waiting
104 gal grey, 104 black,158 fresh
FullBodyPaint, 3,8Kaxles, DiscBrakes
17.5LRH commercial tires
1860watts solar,800 AH Battleborn batterys
2020 Silverado HighCountry CC DA 4X4 DRW
mister_d
I'm just guessing, but I'm assuming it's either from the wheels twisting when I back it up or from hitting a big pot hole. We haven't hit anything that I'm aware of.
Our Adventures
Me '77 DW '78
DD '04 DS '07
Hensley Arrow
mister_d
Luckily I caught it from the sounds of it. I was under the TT today working on the underbelly cover. We just returned from an 18hr drive from Florida the other day .. thank God we made it back without a problem!
I'm a little nervous about this being over my head. Is this as simple as jack up the TT, pull out the bolt, and replace?
Our Adventures
Me '77 DW '78
DD '04 DS '07
Hensley Arrow
