โMar-08-2014 03:12 PM
โMar-25-2014 12:34 PM
โMar-11-2014 02:39 PM
โMar-11-2014 02:13 PM
mkirsch wrote:
Also keep in mind that the "limits" of the DRW truck are largely in the driver's head.
โMar-11-2014 12:54 PM
โMar-11-2014 12:43 PM
โMar-11-2014 12:26 PM
โMar-11-2014 12:17 PM
โMar-11-2014 11:03 AM
jimh425 wrote:
As is always pointed out, it's easier to buy a newer DRW as long as a DRW isn't too limiting in other ways.
โMar-11-2014 10:56 AM
ah64id wrote:
The SRW 19.5's are great, I haven't regretted them once yet. Stable, smooth, and just feel like a better tire. I am glass smooth up to 73, and start to get a slight (really slight) vib at 74-75 that is about the same thru 80 (as fast as I have had them since they have a 75 mph rating). I am not sure if it's tires, driveline, or both.. but the road condition makes it worse. A smooth new road is smooth as glass at 75.
A DRW would help with weight, but I do too much driving on roads where a DRW would be a poor choice.
โMar-11-2014 05:49 AM
okan-star wrote:
What gets me is the front dana 60 on 94-02 trucks. The diffrence between the dually and the single rear is only the unit bearing hubs and the dually spacers . The highest rating I can find for it is 5200 lbs , the front of my truck empty is 4780 lbs , not much to spare, Dana even refered me to that #, it must be more.
http://dodgeram.org/tech/specs/axle/axlespecs.html
okan-star wrote:
Just mulling it over before I spend on SRW vision 19.5 `s
I love my SRW and have way to much on it to start over again , but also looking for used 2001.5-2002 HO Duallys
Your rear axle is way beefy ๐
โMar-10-2014 06:11 PM
jefe 4x4 wrote:
Okan,
At the time i bought the truck the determining factor for me was the higher spline count, bearing and RG&P upgrade, and larger axle diameter that they Just started putting on 3500's with the V-10 option in 2000 and only in 2001.5 to 2002 with the Cummins H.O. engine and NV5600 combo. No D70 parts anywhere to be seen. I know this for when I installed the Power Lok rr limited slip, they had to re drill the D-70 plate to fit the larger RG parts. These did not appear before that time, but were the 'detuned' versions you speak of. If it weren't so I certainly would not have plunked down my cash for a new truck that year. I have a friend with a 17K pound MoHo with a gas 454 and the self same Dana 80 to-the-max under the rear. His is rated at 13,500 pounds. He had a leaky pinion seal and had me crawl under there to see what was what. I got under there and lo and behold it looked exactly like the D80 under my rig. Of course, it's hard to tell unless you take it down to see if it's mostly Dana 70 air inside the pig.
regards, as always, jefe
โMar-10-2014 04:12 PM
โMar-10-2014 10:54 AM
โMar-10-2014 10:43 AM
