Sway control bar >>>
kennyd63
I have a 25 footer T.T. which it sways when windy conditions are present, and semis pass me by.
I am looking on buying a sway bar control bar made by Husky, I notice they sell a right hand and a left hand. My question is on the catalogue they recommend that I buy the L/H and R/H is this is really necessary?.:h
Please advise
Thank you to all for your input in this matter.
2019 Braxton Creek 24RLS
2010 Forest River Salem 403FB-Destination Trailer
2014 F150 4X4 Crew Cab
16 REPLIES 16
owenssailor
I used the ezelift system and sway control bar with a previous smaller lighter trailer. It is not nearly as good as my equal-i zer. I do not get pushed around by transports passiing
2011 Jayco 28U
2012 Chev Silverado Crew Cab 5.3 6 spd 3.42 (sold)
2017 Chev Silverado Crew Cab 5.3 8 spd 3.42
Equal-i-Zer 1400/14000
RotoChocks
beemerphile1
First step is to resolve whatever is causing the sway, then consider an anti-sway device.
Build a life you don't need a vacation from.
2016 Silverado 3500HD DRW D/A 4x4
2018 Keystone Cougar 26RBS
2006 Weekend Warrior FK1900
hohenwald48
Jeremiah,
Thanks for the reply. I frequently hear folks say the friction device built into various hitch designs is somehow superior to the Husky type friction bars. I also hear them say the hitch with built in friction sway control "prevents" sway while the Husky type bars only "control" it.
That sounds like something you'd expect to hear from a politician instead of an RV'r. I just don't understand how they are different as they both use friction as the sway controlling force and they just go about creating that friction in different manners.
When seconds count, the police are only minutes away.
2019 Newmar Canyon Star 3627
2017 Jeep Wrangler JKU
jerem0621
hohenwald48 wrote:
ReferDog wrote:
Get an Equal-lzier with correct bar's 1000 or 1200# go by hitch weight
Why is that better? What's wrong with the add on friction devices?
Absolutely NOTHING. Both types are friction sway controls.
The only difference is that in order to increase friction on an Equal-i-zer and the clones is to increase tongue weight and adjust the hitch.
Sorry, its not for me... I much prefer my old fashioned WD hitches and sway bars... and yes I tried the new fangled expensive hitches... they offer zero over a well set up standard hitch and friction sway control (two if towing 24 ft long or more)... as a matter of fact they can be a negative
If you set up a integrated hitch incorrectly then you have a terrible handling rig.. at least with an add on sway control you can retain friction sway control if the WD hitch isn't dialed in... or heaven forbid.. you experience a WD hitch failure. (Something I have experienced with dual cam sway control and it is NO fun)
I have a back up Weight Carrying draw bar with a sway bar tab that travels with me when I tow. That way I can pull my trailer and use my sway bar in the event of another WD hitch failure.
When we go back to a TT I will do the same... I will have a WC draw bar with dual friction sway bar mounts welded on that will stay with me every time I tow.
Nothing worse than being ready to leave the campground or on the side of the road with a broke hitch and no safe way to get the trailer home. Something a simple draw bar with a few sway bar tabs could do easily.
That means having a vehicle that can handle WC of the tongue weight that your vehicle has.. but thats for another thread.
Thanks!
Jeremiah
TV-2022 Silverado 2WD
TT - Zinger 270BH
WD Hitch- HaulMaster 1,000 lb Round Bar
Dual Friction bar sway control
Itโ€™s Kind of Fun to do the Impossible
~Walt Disney~
hohenwald48
ReferDog
ReferDog 2008 Chevy 2500 HD Dura Max
Artic Fox 30U
Equlizer Hitch
hohenwald48
You can get Curt sway controls from Amazon for around $39. They make a driver side and pax side. For some reason the Driver side was around $80 and the pax side was $39. I bought two pax side units. Took the bar out of one and flipped it over for the drivers side. Works fine except the name sticker is upside down.
GrandpaKip
Please advise
Are you sure the camper is swaying? Does it keep wiggling after the semi has passed or does it immediately go back to tracking straight? Just about any rig is going to get pushed around by gusts or passing semis. Before I got our Andersen hitch, we had the EZ Lift. I never had any real sway problems, but didn't like the little wiggles from being passed. I installed one sway bar and it helped. Then the truck and trailer moved as a unit. The Andersen hitch does the same. I would just get one bar to start.
Good luck.
Kip
2015 Skyline Dart 214RB
2018 Silverado Double Cab 4x4
Andersen Hitch
Terryallan
In truth it shouldn't sway period, UNLESS, you induce sway during some sort of emergency maneuver where you jerk the steering wheel..
Best advice. Adjust the hitch to the point the Tt does not sway in normal driving. THEN add sway control, for those times when you HAVE to jerk it around. For you see. Sway control bars do NOT prevent sway. That is not their function. they are only to help regain control once sway is introduced to the equasion
Terry & Shay
Coachman Apex 288BH.
2013 F150 XLT Off Road
5.0, 3.73
Lazy Campers
owenssailor
I think the factors are:
enough tongue weight - more helps
trailer level or a bit nose down - never nose up
a good hitch system - I like my Equal-i-zer
all tires at max pressure
2011 Jayco 28U
RotoChocks
campigloo
Kenny, don't let people convince you that sway control is just a gimmick. No, it shouldn't sway at all under ideal conditions. Windy areas and large vehicles will push any of them. That sudden gust of wind that comes from nowhere; that stretch of asphalt with a rut in the middle of can cause problems. Just make sure it tracks straight on good roads in calm wind then add your sway control. Cheap insurance to keep it handling well. Don't let pride talk you out of it.
Tachdriver
My two cents. My sig has my stats on it. Mine came with one and ended up buying two, so much more stable when trucks and large vehicles pass. I believe the cost was $80? Well worth it. Trailer is about 6,500 pounds behind a half ton.
lanerd
I assume you have some sort of weight distribution set up...if yes, many can be converted to a Reese Dual Cam system that has built in sway control and will work much better than either a single or double anti-sway friction bar. The cost is a little more, but you will get much better performance.
Good luck and hope this helps
Ron
Ron & Sandie
2013 Tiffin Phaeton 42LH Cummins ISL 400hp
Toad: 2011 GMC Terrain SLT2
Tow Bar: Sterling AT
Toad Brakes: Unified by U.S. Gear
TPMS: Pressure Pro
Member of: GS, FMCA, Allegro
RETIRED!! How sweet it is....
bobndot
Before you buy special equipment searching for a solution ,
make sure you have enough tongue weight .
The design of certain trailers and the placement of the axles on the frame of such trailers can be the culprit.
There are ways to mod a TT to cure this, adjustments can be made and might be, money well spent . The most common reason for sway is not a lack of a sway control bar . Least expensive way is , move items in the TT forward to transfer weight. Try that , then road test it .
Adding sway control is helping but not attacking the core of the problem, its just masking it. A strong enough crosswind or bow wind from a passing truck can overcome sway bars if you have not addressed the core problem. Don't be fooled by a false sense of security because you added a sway bar and it feels better in a moderate wind.
Other factors involve the tow vehicles wheelbase, overhang distance from the tv rear axle to the ball .
