Aug-25-2013 06:56 PM
Aug-26-2013 09:40 AM
Aug-26-2013 09:29 AM
gates59 wrote:
I don't need to take weight off of the rear of my truck. I weight my truck and trailer. Trailer loaded is 5577 lbs and weight my truck only and truck only with weight distribution attached to trailer. The tongue weight with distribution bars attached is 595 lbs. So my guess is the actual tongue weight is a lot more. My weight bars are for 550 lbs max. My truck sits just as I want it too but I do get a little bounce from the trailer. I don't really feel it on my tv thought. I just thought that stronger bars would stiffen the bounce that I'm getting.
Aug-26-2013 09:10 AM
Aug-26-2013 08:16 AM
gates59 wrote:
I have a quick question on a lower weight distribution bars. Mine are somewhere around 150 lbs less than the weight on my tongue. Will larger bars stop the bouncing front to back my trailer makes on bumps.
Aug-26-2013 07:47 AM
Aug-26-2013 06:25 AM
kbravo1974 wrote:
Thanks all. First the tires on the truck are new so air pressures are good. I agree that the dealer should have probably sold me the next size up on the WDH bars given the tongue weight published is over 1000 lbs. I think that my heights are okay, but I will double check this.
I will keep researching this issue. Thanks for your suggestions.
Aug-26-2013 05:23 AM
Aug-26-2013 05:08 AM
Aug-26-2013 03:28 AM
Aug-26-2013 01:07 AM
Aug-25-2013 09:50 PM
Aug-25-2013 07:46 PM
Aug-25-2013 07:38 PM
Aug-25-2013 07:31 PM
Aug-25-2013 07:16 PM
