โAug-17-2017 06:05 PM
โAug-18-2017 03:00 PM
Camper76 wrote:
If I look for trailer around 4500lbs that's probably a 19' trailer. I have family of 4. I'd need to get a 3/4 ton to tow anything bigger.
โAug-18-2017 02:33 PM
BizmarksMom wrote:
It's easy to buy way more trailer than you can safely tow. Every dealer out there is telling people they can tow anything with a half-ton truck. I have an F150 with the max tow package. My hard limit for trailer weight, loaded and ready to camp, is 6000 lbs.
I'm single with 2 dogs, and I happen to know that I have a good 1200 lbs loaded in my trailer when I'm headed out to the desert for 2 weeks. I also know that my bed is loaded with extra water, fuel cannisters, a generator, and the beer that didn't fit in the fridge.
For your truck; a trailer that weighs in around 4500 lbs will give you a comfortable margin.
โAug-18-2017 02:10 PM
โAug-18-2017 01:44 PM
โAug-18-2017 11:58 AM
Camper76 wrote:
Ok it's gvwr is 6,325.
Terryallan wrote:
With that low a GVWR. I'm guessing. Your payload / carrying capacity, is in the 900lb range.
SoundGuy wrote:
Doubt it would be that low, all depends on the truck's dead weight with a full tank of gas, no passengers, no cargo - subtract that number from the truck's GVWR and the OP won't be guessing, he'll know what it's actual payload capacity is.
Terryallan wrote:
Agree. I'm just guessing based on experience. The only way to know is to weigh it. But it would have to have a awful light curb weight to have much more payload than that.
โAug-18-2017 11:44 AM
โAug-18-2017 11:38 AM
โAug-18-2017 11:18 AM
โAug-18-2017 10:59 AM
โAug-18-2017 10:18 AM
normal_dave wrote:
The only Quads with 3.55s, and a max trailer of 8,500 are Laramie, and they have a 6,700 GVWR and a 1,380 payload.
โAug-18-2017 09:56 AM
โAug-18-2017 09:26 AM
Camper76 wrote:
Ok I'm looking at Jayco jay flight 32' fully load its 9000lbs. My truck can tow up to 8500lbs. I know I'll never fully load it. Would you buy it or stay clear of it?
โAug-18-2017 09:11 AM
โAug-18-2017 08:53 AM
โAug-18-2017 08:24 AM
drsteve wrote:
Look at the tire inflation sticker inside the driver's door. It will say something like "the weight of passengers and cargo should not exceed xxxx lbs. That is your particular truck's payload capacity, and it is the limit you will reach first when towing with a half ton truck.
