You don't say what tire pressure you are running, but check that. I'm not sure why you want to move away from the current tires. What goal do you have?
You do probably need shocks but some movement in wind is going to happen. Use as little Air Bag pressure as you can get by with to ensure the springs are doing most of the work which are progressive.
Do something to make the overloads engage. There are a lot of different methods if you search here to fill in the space on front and rear overload bump stops.
I use Energy Suspension bump stops. They are relatively inexpensive and help. I've used these on both my 2006 F350 SRW and now on my 2010 F450 DRW.
http://smile.amazon.com/Energy-Suspension-9-9109G-Heavy-Duty/dp/B000CN5GRC?ie=UTF8&psc=1&redirect=tr...
