Jan-13-2022 06:24 AM
Jan-18-2022 02:39 AM
valhalla360 wrote:
The oil embargo was 40-45yrs ago...not particularly relevant to today.
Jan-17-2022 08:13 PM
Jan-17-2022 05:21 PM
spoon059 wrote:rhagfo wrote:time2roll wrote:
I want super singles tucked under the SRW fenders instead of a dually. Going to be a bit narrower between the wheel wells and that is fine by me.
I doubt manufactures would produce a truck with less than 4’ between the wheel wells.
Yea, I've thought of that as well, but I agree.
I haven't looked at a dually in a while, but I have to wonder if the inner wheels could be tucked closer to the body, thus bringing the outer wheels closer in as well. That would reduce the overall width by a couple inches, possibly making it more desireable.
Or simply offer a super single (17" wide) instead of dual rear wheels (23" wide). That would reduce your width by a foot! Of course, I'm not aware of a super single with a wheel size small enough to fit on a pickup...
Jan-17-2022 04:28 PM
JRscooby wrote:valhalla360 wrote:
As mentioned HDT are a different world and not relevant to your 3/4 & 1 ton pickups. I would expect your average trucking company has qualified mechanics performing work. Your average guy with a 20yr old truck that he's stringing along likely cuts a lot of corners...so your assumption that the engine transfer would be done professionally is sketchy at best.
I'm sure individuals mostly could care less about the engine technology but that doesn't mean it must meet current regulations and that it must mate with the new technology on your new chassie.
As far as keeping a truck going for 40yrs...if you dump $40-50k into the chassie, you can do a major overhaul making it like new at 20yrs (probably a good bit cheaper if you don't live in rust belt states)...giving you an additional 20yrs. If it's really that the engine will last 40yrs, you can keep the chassie going and it's much more straight forward.
Back in the days before oil embargo...........
Jan-17-2022 02:07 PM
Jan-17-2022 08:03 AM
Jan-17-2022 03:07 AM
Jan-17-2022 01:31 AM
Jan-16-2022 09:13 AM
Until you ever have to drive in snow and all they do is float.
Jan-16-2022 08:51 AM
Michelle.S wrote:
Biggest problem with the F450 besides the rear-end is the fact it generally has a lower cargo capacity than an equally equipped F350 since the overall Truck is heavier.
Jan-16-2022 08:11 AM
What would that do for you over a 3500 SRW with 18's that have a lot of carrying capacity ?
Jan-16-2022 07:33 AM
Jan-16-2022 06:34 AM
Jan-16-2022 01:09 AM
Jan-15-2022 10:26 PM
