โDec-05-2013 02:25 PM
โDec-19-2013 09:53 AM
Hannibal wrote:transamz9 wrote:06Fargo wrote:
I like peanuts.
The Big Fight to remove rear wheels is a often overlooked side benefit of a dually.
Consult your local tire experts or the Tire & Rim association before putting anti-seize compounds on wheel mountings regarding getting correct torque values afterwards.
I've never had a problem with a Ram or a GM but the SD lug nuts have a locking devise in them that can be a major PITA. The problem with them is that there is enough play in the nut and locking washer that you loose all the torque the impact has to remove it. On a dually, you almost have to use a long anvil impact to be able to get to the lug nuts. If you use an extension you will loose torque . My 1/2" drive impact has 1200 ftlb of torque and there are times I have to break out the 5' strong arm to break some of our SD lug nuts loose.
Those aren't lock washers. They're flat washers that require a drop of motor oil between the nut and washer to prevent seizing. Works like a champ. I much prefer them over my previous Ram's lug nuts.
Do long bed crew cabs make less rear wheel torque than reg cab short beds due to the length of the drive shaft? I've never heard of the length of a shaft reducing torque.
โDec-19-2013 09:28 AM
fj12ryder wrote:
Aluminum alloy lug nuts? I don't know what year the OP's truck is but my '01 Dodge dually has steel lug nuts and steel wheel studs. But I also have steel wheels.
โDec-19-2013 06:08 AM
โDec-09-2013 11:43 AM
I like peanuts.
โDec-09-2013 11:07 AM
โDec-09-2013 07:24 AM
06Fargo wrote:
I like peanuts.
โDec-09-2013 04:04 AM
โDec-09-2013 03:01 AM
โDec-08-2013 09:13 PM
Hannibal wrote:Old-Biscuit wrote:Hannibal wrote:Huntindog wrote:pigbike wrote:
So for right now I am just soaking my nuts, hoping for good things to happen.
An activity I whole heartily recommend:B
On our last camping trip, I boiled mine so we could all enjoy 'em!:B
Where did you get green peanuts for boiling after Sept.?
Certainly you didn't use dried ones......that's just wrong :B
Sometimes you just have to improvise. They weren't too bad but the 5th wheel sure stunk.:o
โDec-08-2013 03:23 PM
โDec-08-2013 09:54 AM
โDec-07-2013 02:27 PM
โDec-07-2013 01:50 PM
โDec-07-2013 12:53 PM
Me Again wrote:pigbike wrote:
Well my nuts are back to normal. I went out this morning and broke everyone of them loose with my 1/2 drive 16" breaker bar. No extra pipe needed.
Why the Dodge dealership couldn't do it is beyond me. I'm 63 and didn't even break a sweat doing it by hand. Now I did spray then with penetrating oil several times since going to the dealer but they are not rusted at all. Once I broke them loose I could remove them the rest of the way by hand.
I bet the tech at the dealership is one of these guys who doing tires is below his perceived worth, so he just made up an excuse not to do it.
I will be calling the dealership on Monday.
Just remember lug torque numbers are based on dry clean studs and lugs. That is without lube or anti seize.
Chris
