Tires - Preferences?
Ventura_Dogman
I am running a Chevy diesel 3500 with a Northstar Laredo on the back. I do a little off-roading, but nothing radical. Mostly 4wd is for sand, mud and snow. I do drive some dirt roads with sharp rocks, like out to the Racetrack in Death Valley (I typically air down and go slow). I am looking for E rated tires that have some off-road ability, but are reasonably quiet and efficient on the highway. I know the two are often mutually exclusive but I thought I would ask.
Any recommendations or thoughts?
Northstar Laredo SC
Chevy Silverado 3500 diesel 4x4
Yellow Labrador co-pilot
23 REPLIES 23
Ventura_Dogman
d3500ram wrote:
Good tires aren't cheap. I figure at least $250 a corner before any tax, disposal, road hazard, etc.
The M55s were $300 before any of the other costs. The Hankook Dynapro ATM RF10s are $145.
Northstar Laredo SC
d3500ram
Sold the TC, previous owner of 2 NorthStar pop-ups & 2 Northstar Arrows...still have the truck:
2005 Dodge 3500 SRW, Qcab long bed, NV-6500, diesel, 4WD, Helwig, 9000XL,
Nitto 285/70/17 Terra Grapplers, Honda eu3000Is, custom overload spring perch spacers.
Ventura_Dogman
I just priced the Toyo M55 at a local tire chain (that usually has very good prices posted on its site). Man, those are expensive tires!
Northstar Laredo SC
Grit_dog
Navigator
Navigator
deserteagle56 wrote:
woodhog wrote:
Ventura Dogman wrote:
I am running a Chevy diesel 3500 with a Northstar Laredo on the back. I do a little off-roading, but nothing radical. Mostly 4wd is for sand, mud and snow. I do drive some dirt roads with sharp rocks,I do drive some dirt roads with sharp rocks, like out to the Racetrack in Death Valley (I typically air down and go slow). I am looking for E rated tires that have some off-road ability, but are reasonably quiet and efficient on the highway. I know the two are often mutually exclusive but I thought I would ask.
The "sharp" rocks are the problem, I don't know of any E rated tires that have good sidewalls that will not cut with a sharp rock, with our heavy campers on, the E rated tires bulge out on the side walls, the sidewall effectively becomes the tread, the rocks tear out the side wall of your tire, its just a matter of luck/time...
Don't know as I've ever seen sidewall bulge on a Toyo M55 inflated to its max. I'm willing to bet if I were to mount a set on my Jeep I wouldn't have to put any air in them. Stiffest sidewalls I've ever experienced on a tire.
Now if Toyo would make more sizes in the M55 they'd be golden.
FWIW, I've run a fair amount of roads/trails with rocks with the camper on Toyo MTs and didn't tear up a tire.
Maybe I dodged all the sharp rocks, maybe they're good tires...
Ventura_Dogman
Stock is 265/70-18, which is what I am looking for in a E rated tire. Yes, SRW.
Northstar Laredo SC
d3500ram
I am running a Chevy diesel 3500 with a Northstar Laredo on the back. I do a little off-roading, but nothing radical. Mostly 4wd is for sand, mud and snow. I do drive some dirt roads with sharp rocks,...~snip~
From your description, I assume your truck is a SRW?
What diameter rims are on your truck?
Ventura_Dogman
Anyone ever try Hankook Dynapro AT-Ms? Consumer Reports listed it as their top AT pick.
Northstar Laredo SC
_DJ_1
idaho_camper wrote:
bedrocker wrote:
I'm on my second set of Toyo M-55's love em ๐Ÿ™‚
^^ I'm running Cooper ATP's on my rig. But if price were no object, I'd definitely be running M55's. They are an exceptionally built tire. I recall them being an actual medium duty tire. I think the national guard runs them on many of their vehicles because they're so stout.
I ran M 55's on my 05 CTD dually. Took all the fun out of winter driving. Rarely needed 4X4!!! :C
'17 Class C 22' Conquest on Ford E 450 with V 10. 4000 Onan, Quad 6 volt AGMs, 515 watts solar.
'12 Northstar Liberty on a '16 Super Duty 6.2. Twin 6 volt AGMs with 300 watts solar.
profdant139
We use BFG A/Ts. We do a lot of off-pavement travel and towing, with sharp rocks, snow, mud, and ice. We like them. Have not done much sand -- except in Death Valley.
But they are noisy on the pavement, and there is an MPG penalty for tires with an aggressive tread. Life is a series of compromises.
2012 Fun Finder X-139 "Boondock Style" (axle-flipped and extra insulation)
2013 Toyota Tacoma Off-Road (semi-beefy tires and components)
Our trips -- pix and text
About our trailer
"A journey of a thousand miles begins with a single list."
deserteagle56
1996 Bigfoot 2500 9.5 on a 2004 Dodge/Cummins dually
nomadictxn
996Pilot wrote:
My 2015 RAM Mega CTD came with a new set Pathfinder Sport A/T's. They are a generic "Americas Tire" brand manufactured by Kumho and closely resemble the Kumho Road Venture SAT tire. These tires blow away the Coopers on the highway for quiet, handling, etc. Was in desert sand with them a couple weeks ago and they did xlnt. 25% cheaper than the Coopers. I only have 8000 miles on them but they look like they are wearing nice/normal.
I bought a set of these tires in June to try them out. 5k miles and love them. They are quiet on the road. I am running 275,70,18 and am curious to see how they do in winter.
nomadictxn
2013 RAM 1500 QC 5.7, 3.92 4x4 6 sp.
2021 Flagstaff E Pro 19FBS
joeshmoe
I was going to go with the S/T MAXX, but decided on the ATP. Considered Nitto Terra's. Too many complaints about supposed failures.
2014 Northwood Wolf Creek 850
2005 Ford F350 SRW SuperCab/LongBed 6.0 Powerstroke
QuickTrick's Towing Tune
Torklift Tie Downs/Fastguns/Upper/Lower Stableloads
Rancho 9000's
woodhog
2004.5 Dodge 4x4 SRW Diesel, 245/70R19.5 Michelin XDS2, Bilstein Shocks
Torklift Stable loads, BD Steering Stabilizer Bar, Superchips "TOW" Programed,Rickson 19.5 wheels
2006 8.5 Northstar Arrow, 3 Batteries 200 Watts Solar,
12 Volt DC Fridge.
Strabo
joeshmoe wrote:
Pretty happy with my Cooper ATP'S. Have about 5k on them. Surprisingly quiet on the hwy considering the tread. I also only do light off roading. Mostly loose/soft sections of sand. But with these tires, with the camper on, I've yet to need to shift into 4wd.
E-10 rated tire @3650 lbs.
cooper atp
I have the STT Pros, great tires.
04' F350 PSD TB SC FX4 XLT, TH-04' 32' Sandpiper Sport Fifthwheel WB Dual Axle
07' Rhino 686 SS106-ITP-AFE-BRP-T4-CDI-KIBBLEBWHITE-CVT-TSTICH-Ridgid LED LightBar-HID Conversion Kit-LIVEWIRE
04' Honda 250 Sportstrac quad
05' Honda 400 Ranchers quad
