Totally Confused
Big_Rig1
I was checking my fuses today & noticed that the refrigerator has a 20 amp fuse in the 12 volt feed. I have a Norcold 2 way fridge so it doesn't have a 12 volt heater, the 12 volts only runs the circuit controls. The sticker that shows all the fuse sizes in the fuse box also lists the frig as having a 20 amp fuse. I checked the sticker on the frig & it shows the 12 volt amp draw as 1.2 amps. The installation manual says the maximum fuse size should be 6 amps.
So why do I have a 20 amp fuse????
Big Rig (John)
04.5 Dodge Quad,3500,CTD,DRW,4X2,48RE, Ranchos, Tatman Wedgies
2015 Arctic Fox 990, 100W solar, power rear awning, Fox Landing, no generator, no oven
6 REPLIES 6
trail-explorer
Grit dog wrote:
Prolly because most every AF camper has a 3 way fridge as they typically have a lot of amenities.
..and they wire them all the same, regardless of which option it has.... but from my experience, a 3-way Fridge in an AF camper is a special order.
Bob
rickeoni
Battrey charger on the convertor is usually on the fridge circuit.
2008 F450
2007 Adventurer 85WS
2012 Haulmark "The Garage"
2016 Outdoors RV Glacier Peak 26 RKS
Old-Biscuit
Fridge DC Circuit FUSE on circuit board will only be 3A........so 20A supply fuse is a NON-ISSUE
Could be 20A also used for 'other' components (feeder for water pump, possibly water heater)???
Grit_dog
Navigator
Navigator
Prolly because most every AF camper has a 3 way fridge as they typically have a lot of amenities. Since you ordered yours, or bought one with a 2 way it was likely out of the norm when it was produced.
Won't hurt anything I'd guess as the wiring is probably the standard gauge to power the DC heater, but the most correct and conservative thing to do since you noticed it is replace with a 5amp fuse.
hedge
delete
2017 F350 Platinum DRW
2013 Adventurer 89RB
ChooChooMan74
I would say, cost cutting. Manufacturer probably buys fuses in bulk, and they just buy 20s.
Great American Anti-Towing Conspiracy
2015 Ram Truck 1500 Ecodiesel Tuned By Green Diesel
2006 Jeep Liberty CRD Tuned By Green Diesel (Retired to Daily Driver)
2015 Rockwood Roo 183
Stop on by and read my Camping Blogs
Nights Camped in 2015 - 19 and Winterized
