โJun-20-2017 01:52 PM
โJun-21-2017 11:33 AM
โJun-21-2017 11:19 AM
โJun-21-2017 08:28 AM
SoundGuy wrote:gmc6000 wrote:
No, tow/haul does not lock out overdrive on any GM or Ram truck, at least. Tow/haul only changes your shift points on the transmission.
I guess it depends on what one means by "overdrive" but I recently bought a 6-spd 2012 Silverado 1500 to replace our 2005 4-spd Avalanche for towing and in Drive when I engage Tow/Haul it absolutely does lock out 6th gear. If I disengage Tow/Haul while towing at highway speed and happen across a relatively flat section of road only then will the transmission upshift to 6th, otherwise with Tow/Haul engaged the highest it will go is 5th, which as it turns out is right where it needs to be - 2000 rpm in 5th, downshifting occasionally to 4th as road conditions may require.
โJun-21-2017 07:48 AM
Cummins12V98 wrote:Bedlam wrote:
You were told wrong.
I should have added when towing at let's say 60.
My 68RFE would tow at 60 in 6th all day with 3.42's on flat ground with tH and EB engaged.
MeAgain???
โJun-21-2017 06:53 AM
โJun-21-2017 04:13 AM
Cummins12V98 wrote:
From what I have been told tow haul will not allow use of 6th with the AISIN trans.
MeAgain what say you???
โJun-21-2017 04:04 AM
โJun-20-2017 10:17 PM
โJun-20-2017 09:56 PM
โJun-20-2017 09:32 PM
Bedlam wrote:
Tow/haul changes shift points for upshifts and downshifts. It also tries to keep the torque convertor locked to keep transmission temperatures down. You can still lock out higher gears with the shift selector if the transmission is hunting between gears due to your load, speed and terrain combination.
โJun-20-2017 08:50 PM
If your truck normally shifts into overdrive at, lets say 55 MPH, in tow/haul mode you may need to hit 60-65 before it shifts into overdrive.
Same for Ford. At least for the last 10 yrs or more.
โJun-20-2017 04:48 PM
โJun-20-2017 03:32 PM
โJun-20-2017 02:51 PM
โJun-20-2017 02:09 PM
