Tow Vehicle for 10k bumper pull
CampingFamily10
My travel trailer is a 2020 Keystone Outback 340bh. About 40 ft long and 8800 lbs u loaded / max 10500 loaded. We have a permanent spot but will still probably travel 1-2 times a year up and down the east coast with the worst being Allegheny mountains in PA. Because I won’t tow frequently I am looking at probably going gas truck again as I replace my current Ram 1500 with the 5.7.
Any recommendations when comparing the big 3? I’m probably looking for a 2014 - 2017 used 2500/F-250. Seems like the 6.4 HEMI does well but with a weak transmission. A lot of people think the 6.0 is underpowered and I’ve heard the 6.2 is pretty comparable as well. I don’t really have any allegiance to a brand.
35 REPLIES 35
Grit_dog
Navigator
Navigator
Lol, no I just hope that providing a little reality will help the impressionable folks that are asking the questions! Cheers!
spoon059
Grit dog wrote:
Lwiddis wrote:
Weight wise a 3/4 will do it but at 40 feet I'd get a one ton. That's a bunch of tail for a dog to tow.
But a 1 ton dog is the same size as a 3/4 ton one, regardless of how big his tail is...
Never let reality get in the way of the RV.net weight police... don't you know better by now!!!???!!!
2015 Ram CTD
2015 Jayco 29QBS
spoon059
Honestly the 6.0 is plenty of truck. My FIL tows an 8500 lbs trailer with his 6.0 and has plenty of power. The PA mountains bring his fuel economy to 6 or 7, but he can easily maintain highway speeds up those grades. Any of the big 3 will do fine, but definitely get a 3/4 or 1 ton truck for that weight.
The older Ram 6.4 with the 6 speed had plenty of power, but the transmission gearing was wonky at best. Maybe try to find a 4.30 rear axle 6.4, apparently those work better with the transmission ratio on the 6 speed.
Ford 6.2 has plenty of grunt and should handle those weights just fine.
Did your 5.7 have enough power? You can still get a 2500 with the smaller Hemi.
Just remember though, a gas engine needs to rev more to make power. There is nothing wrong with towing at 2500 RPM and occasionally revving higher to pull grades. That is exactly how they are designed to work. Any modern 3/4 ton truck with a gas engine should be able to handle those weights... especially just a couple times a year.
2015 Ram CTD
2015 Jayco 29QBS
kw_00
The GM 6.0 is far from being underpowered, any gas job will work for you especially with the 6 speed transmissions.
A truck, a camper, a few toys, but most importantly a wonderful family.
Me_Again
2x4 35K+
https://www.31dodge.com/new/Ram/2019-Ram-2500-kernersville-2818f47d0a0e0ae97bdec050ff637cb9.htm
4x4 38K+
https://www.31dodge.com/new/Ram/2019-Ram-2500-kernersville-9d08a82f0a0e0ae7453a4472d18a02e1.htm
4x4 is nice looking. Chris
Window sticker.
https://www.ramtrucks.com/hostd/windowsticker/getWindowStickerPdf.do?vin=3C6UR5CJ5KG577198
valhalla360
Nomad III
Nomad III
Huh? Unless you move up to a dually (overkill for 10k), they are essentially the same truck.
Modern gas V8's are largely all over 350hp...so plenty of grunt.
Our 2008 V10 is rated at 365 and many are pushing up close to 400hp.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
wowens79
I’ve been looking and researching trucks, and started looking at 2-3year old trucks, but looking at prices it looks like new ones are not much more, so I’m looking new.
All 3 have made big changes for the 19’s and 20’s
Ram in 2019 went to an 8 spd trans, and people are loving the new trans. The old 6spd was solid, but had bad shift points, and internal gear rations
Chevy upped the engine to a 6.6 liter for 2020, but left the 6spd trans and it seems it has bad shift point like the Ram had.
Ford just realeased a 7.3 liter gasser with a 10 spd tranny, and it is getting every ones attention. It seems to be a real beast.
2022 Ford F-350 7.3l
2002 Chevy Silverado 1500HD 6.0l 268k miles (retired)
2016 Heritage Glen 29BH
2003 Flagstaff 228D Pop Up
Grit_dog
Navigator
Navigator
dodge_guy
If you can find one of the last year F250's with a V10? that's what I would do.
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
1320Fastback
Even my old 1st Gen Dodge is rated to pull 11,600 so I would hope any modern 3/4 ton could do it too and if I was only going to pull a few times a year would go with a 3/4 ton.
1992 D250 Cummins 5psd
2005 Forest River T26 Toy Hauler
blt2ski
Moderator
Moderator
Not saying you will find either of these.
GM has a 1500 with a 6.2 V8 with more HP torque than a 23/35 series truck. I know of one person pulling a 12kbboat from E Was over Stevens pass at 50+ on 4-5% grades. That is plenty fast for that road. An interstate would be 60'ish.
The other, probably a better chassis setup. Ford's F150 has an 8400 gvw option with the 3.5 Ecoboost. So no loss of power until you hit 8-9000' elevation, which I don't believe is possible on east coast. Last year or two has an 8 or 10 so auto.....
With a WD system, either of these has ability to pull you just fine too. Only issue, might be payload, depending on hitch weight, passenger wts etc. When I had 4 adult sized teens, that trailer, I would at or just above these two trucks abilities chassis wise, power no. A couple, these are options. Family of 6 that weighs in at 1200-2300 lbs, not happening.
Marty
92 Navistar dump truck, 7.3L 7 sp, 4.33 gears with a Detroit no spin
2014 Chevy 1500 Dual cab 4x4
92 Red-e-haul 12K equipment trailer
blt2ski
Moderator
Moderator
2014 and later, seem to have mower power than the 13and older models. At least with three manufactures I know in gas. The GM 6.0 iirc has 350+ ponies to move you along. If that does not work I. A 25/35 series SW rig. Then you're in trouble!
Not positive on power specs of other two brands, I would suspect they will motor you along just fine too.
Buy the one wife likes, star traveling.
Marty
IdaD
Any newer 2500 or 3500 truck, gas or diesel, would do nicely.
Price new trucks too. I suspect the incentives may get real appealing pretty soon and new may compare favorably to lightly used.
2015 Cummins Ram 4wd CC/SB
wanderingaimles
rexlion wrote:
Here's what you need. Go big or go home! 😉
Rex, thats ok if you have a pop up, he has a 30+ foot tt.
rexlion
Mike G.
Liberty is meaningless where the right to utter one's thoughts and opinions has ceased to exist. That, of all rights, is the dread of tyrants. --Frederick Douglass
photo: Yosemite Valley view from Taft Point
