Jan-09-2021 07:07 PM
Apr-13-2021 07:22 PM
philh wrote:
you will not find one single OEM Engineer that will have this conversation with you. Legal liabilities to mfg are extremely high, and that engineer would be fired on the spot.
I gave you some suggestions to do your own research. What did you find doing a comparison between 1T and 3/4T. Crawl under the trucks and compare part numbers between same model year trucks.
Apr-13-2021 05:48 PM
Apr-13-2021 03:44 AM
JIMNLIN wrote:
Ognend....gvwr and gvwr based payload sticker numbers are always a hot item on rv websites. This from another rv website weight thread .....
grindstone01
Senior Member
Registry
*** I'm a retired auto engineer and Marketing has a big impact on GVWR. As a engineer, it was our job to make sure the frame, brakes and powertrain components were designed well above the GVWR ratings that Marketing wanted, so we would design in a safety factor for each component. You don't really think we would build a truck and then test it to determine what the surprise GVWR number should be!
Axle ratings are also well above the GVWR rating and in commercial vehicles, axle ratings are the pay load determining factor and even they have a big safety factor designed into them.
It would be unusual for a lawyer to accept a overweight case unless it was grossly over the safety factor weight and even then a vehicle manufacture would not share that info because it is not a hard fast number that will break if one more pound is added.
There are many videos of million pound plus loads being moved by trucks across country. It's all about the axles.***
Your on the right track...so enjoy the truck/trailer combo. We really like our old '03 2500 Dodge/Cummins HO NV5600 manual tranny pulling our even older '97 11200-11400 lb rv trailer all over the USA.
Apr-13-2021 03:34 AM
philh wrote:
You want to exceed payload capacity, that's your business.
philh wrote:
Are you aware of all the suspension, tires, and axle differences between a higher capacity truck and your truck? It used to be, and it's been a long time since I looked, the 1 ton spring is slightly different to the 3/4 ton, with an extra leaf. I also know there are lower capacity tires available on both models. You also have to deal with GVWR differences between 1T and 3/4T. I believe the rear axle is the same for the same ratio.
philh wrote:
You're convinced you're absolutely right and don't think Ford measured things correctly. I will tell you that most OEM engineers are generally top of the heap, getting recruited from all the top schools.
Apr-12-2021 08:23 PM
Apr-12-2021 07:32 PM
Apr-12-2021 05:03 PM
BenK wrote:
The OP asks a technical question that requires a deep technical & engineering process answer, then dismisses it as too technical...only wanting an answer that fits what they want to hear...to which think they don’t truly know what they want to hear...
Done with trying to help and blocking this one...bye...
Apr-12-2021 04:59 PM
Apr-12-2021 04:52 PM
Apr-12-2021 03:56 PM
Apr-12-2021 01:33 PM
Apr-12-2021 12:50 PM
Apr-12-2021 12:38 PM
Cummins12V98 wrote:
Jerry you painted a vivid and beautiful picture with your explanation. :B
