Oct-01-2017 07:17 AM
Oct-03-2017 11:54 AM
burningman wrote:
how many of you use a hitch extension when your camper isn't on and you don't have to? Why not?
Oct-03-2017 11:50 AM
Oct-03-2017 09:12 AM
deserteagle56 wrote:
Absolutely correct.
Rather than modifying my trailers my solution was to sell the old trailers and custom order new ones with an extended tongue. The trailer manufacturers had no problem with that, and the added cost for the tongue extension was only about $100.
Oct-03-2017 08:43 AM
Oct-03-2017 08:21 AM
mkirsch wrote:
The problem with tongue extensions is you can't extend a trailer tongue with off the shelf, bolt on parts. To do it "right" you need to have the extension properly designed for the trailer and properly installed by someone skilled in the art and science of welding. It's not something you can just do in your garage with a $90 Harbor Freight flux core welder.
Oct-03-2017 07:11 AM
Oct-03-2017 06:50 AM
Oct-02-2017 01:20 PM
languiduck wrote:
Depends on the load you are carrying. If it's a light load I'd use an extra long ball mount or fabricate one. Those extensions suck to use. Too much slop.
If you're towing heavy you could extend the tongue...maybe. It will make it a PITA to hook up because you'll be reaching under the camper. Then you have a good chance of jamming the tongue up in the camper at something like an uneven intersection or any ground with a drastic elevation change.
Oct-02-2017 12:08 PM
Oct-02-2017 07:06 AM
jmtandem wrote:which is better structurally
Which is better for what? The truck or the trailer. I would go with a longer tongue for the trailer if all other things were equal. If you extend the tongue of the trailer be certain that the tongue extension can handle the trailer's weight. Otherwise there is always Torklift that makes a truck receiver and an extension that is strong and works.
Oct-02-2017 06:36 AM
Oct-02-2017 05:35 AM
Oct-01-2017 10:29 AM
Oct-01-2017 08:10 AM
