TV tire life
poorboy
I'm sure its been talked about in the past, but I can't find it. I have Good Year tires on my p/u with only 30k miles and lots of tread left, but they are original tires. The sidewalls are clean no cracks or scuffs. Can they last longer or do I need to replace them. I replaced the tires on the TT every 5 years, the last time I used GY endurance. I was thinking about Michelin LTX for the P/U, what do you all use. Thanks in advance for your help.
2013 Chevy 2500 CC LTZ D'Max 4x4
2014 Jayco Eagle 298RLDS
2013 Harley Davidson Ultra Limited
2017 peterbilt.
Truckin 38 yrs. Car Hauler 25 yrs. Camping my whole life
39 REPLIES 39
I am a strong believer in the Michelin LTX. I have had them on several vehicles.
I believe they became the Defender series a few years ago.
I did see something where they may not be available in my size for my Dually. That's a shame, I want more of the same when I replace them.
Mine have 114,807K - 71,338 miles on them and starting to get close to the end. Might hit 75000 miles but not a lot more. They are awesome tires. They will be 5 years old May 19th.
2007 GMC 3500 dually ext. cab 4X4 LBZ Dmax/Allison - 2007 Pacific Coachworks Tango 306RLSS
RV Rebuild Website - Site launched Aug 22, 2021 - www.rv-rebuild.com
jdc1
If you're replacing tires with 50% treadwear left, why waste money on expensive tires that have 1,000,000 treadwear rating?
Like Vahalla360 said, find a decent set on sale and save $$$$$ for camping. I love Michelin, but not for a truck that only goes 6-7,000 miles a year.
JIMNLIN
michelin website.... Q&A
*What is the expected service life of tires?
**While most tires will need replacement before they achieve 10 years, it is recommended that any tires in service 10 years or more from the date of manufacture, including spare tires, be replaced with new tires as a simple precaution even if such tires appear serviceable and even if they have not reached the legal wear limit.**
I've bought tires for my trucks since the late '50s. Lots of tire brands..... but the last 20 years or so I use mostly Bridgestone P and LT tires on my trucks.
Grit_dog
Navigator
Navigator
bob213 wrote:
I had 7 year old Michelins on my truck with only 15,000 miles. Parked in garage at all times when not in use. I had a blowout on I-40 just east of Barstow, CA that did $3500 damage to my rear quarter panel. Not an experience I want to have again. Discount Tire will not fix a tire over 7 years old if it has a nail in it so take that as a guide. I would not go over 7 years without replacing.
They don't call em Michiblows for nothing, lol.
On a serious note, I've has Michelins (and other brands) that showed cracking after only a few years and other tires that showed no outward evidence of age at double that or more.
And a "blowout" isn't evidence of a bad tire necessarily unless one can say with certainty that there was no damage that occurred or road hazards that contributed or caused the blowout.
bob213
You can avoid reality, but you cannot avoid the consequences of avoiding reality โ€“ Ayn Rand
Cummins12V98
Run em til they need replacing.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
Old-Biscuit
There is NO recommendation for car/pickup tires....that 5-7 yrs is for Trailer tires due to sitting stationary for long periods
If your truck sits...then maybe
valhalla360
Nomad III
Nomad III
The recommended is 5-7yrs.
If the truck gets regular use, I might lean toward the upper end of the range. A little bit of flexing while driving tends to redistribute the plasticizers in the rubber negating some of the UV degradation. If the truck is only used 3-4 times a year during trips, I would lean more toward the lower end.
A good option is as you hit 5yr start looking for tire sales. If you get them for 20% off, losing a year or so of use on the old tires isn't much of a hit.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
dodge_guy
If the vehicle is stored indoors I would easily go 7 years. If not then inspect them. Car tires can last longer than trailer tires. But if your not sure, then replace them. The tread is probably around 50% so they are nearing the end of their useful life anyway.
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
Second_Chance
Generally speaking, tires should be replace every 5 - 7 years due to age, regardless of tread wear. I have the Michelin Defenders on our truck and I'm very happy with them. My only complaint is that the tread is a little more open that the OEM Cooper tires so they pick up gravel more on gravel surfaces (like in campgrounds, etc.). My BIL who is a veterinarian/farmer/RVer/truck rebuilder won't use anything but the Michelins on his truck, either.
Rob
U.S. Army retired
2020 Solitude 310GK-R
MORryde IS, disc brakes, solar, DP windows
(Previously in a Reflection 337RLS)
2012 F350 CC DRW Lariat 6.7
Full-time since 8/2015
