โApr-20-2016 11:31 AM
โMay-02-2016 12:35 PM
โApr-25-2016 06:01 AM
Fnp5150 wrote:
I have a 1 year old Jayco TT that weighs a little over 5000lbs loaded. A neighbor recommended I replace the tires that came on it with heavier duty tires to decrease the risk of a blow-out. Is this needed? If it's a common problem, then for sake of safety I probably will. Just hate replacing practically new tires.
โApr-25-2016 05:02 AM
hawkeye-08 wrote:
We bought an used 1998 Terry trailer in 2008. It had the original tires, previous owner keep the trailer inside shop for storage, under car port during the season. We had to replace the rubber valve stems due to leaking, but the tires lasted until 2013. I'm not saying all tires will last that long, but they can. Check the pressure each time before you go out, make sure you have a good spare.
โApr-25-2016 01:07 AM
โApr-24-2016 10:20 PM
โApr-23-2016 06:55 PM
โApr-23-2016 05:21 PM
lbrjet wrote:
I would spend my money on a TPMS instead. I too have over 20,000 miles on my trailer and am on my 2nd set of ST tires both made in China. The OEM tires were Duro 2100 radials and the second set I put on are Hercules Power STR. 6 years, 34 states and no blowouts.
โApr-22-2016 09:32 AM
โApr-21-2016 07:17 PM
โApr-21-2016 06:18 PM
โApr-21-2016 10:09 AM
bobndot wrote:
I would doubt that Jayco or anyone else would honor the 2nd year warranty if YOU listened to your neighbor.
Therefore you have to wait one more year if that matters to you.
โApr-21-2016 07:22 AM
โApr-21-2016 05:50 AM
โApr-21-2016 04:10 AM
heartlandlover wrote:
ST Tires might get you 20 to 30,000 miles but thats not enough for me. I've been RVing for over 30 years and I would run nothing less than Michelin XPS RIB tires on my 41 foot 5ver. I have almost 60,000 miles on them and still have probably another 20,000 or so left on the tread. The good thing about these tires are they are re-groovable which means at least another 10,000 miles. They are 14 ply sidewall and made from the same rubber compound as over the road commercial truck tires. They are not cheap but after buying 3 sets of ST tires which might get you this kind of mileage combined you actually come out cheaper buying the Michelin tires. Thats just my opinion but if your gonna invest in a nice RV then don't go cheap on the tires that you depend on to get you where your going.
