Using a 2011 Ford F150 as a tow truck???
baitboy
I have a 2011 F150 that I am using as my tow truck and I was wondering if any of you who use the newer F150's as tow truck----do you lock out 6th gear when you are towing?
26 REPLIES 26
Dave_H_M
Actually, I am not sure if my trans technically has an "over drive".
I have heard "rumors" that the top two in the 6 speed ford are over driven. I don't know though.
Tvov
Interesting about the different transmissions. My 2008 F250 has the 5 speed Torq-shift transmission. I can't "lock out" over drive, but in Tow/Haul mode the truck won't shift into it until cruising on long, flat stretches of road.
_________________________________________________________
2021 F150 2.7
2004 21' Forest River Surveyor
Mvander
Same drive train and similar wt. trailer. Sometimes i lock out 6th depending on the terrain and the speed I want to travel. The tow mode seems to be pretty good at knowing which gear will work best.
55 FEET OF FAMILY FUN!
2014 F150 HD
2015 Grey Wolf 29DSFB
Dave_H_M
MitchF150 wrote:
Regardless of the engine or even the gear ratio, if the trans shifts in and out of 6th to 5th a lot, I lock out 6th.. Depends on the road, wind, speed limit, etc..
And I've got the EB and 3.73 gears and only towing a #5000 TT...
I did the same thing with my old 97 F150 towing the same TT and locking or not locking out OD (E4OD trans).
So, as I said, for me, it just depends... ๐Ÿ˜‰
Mitch
I run my Ford the same way. It is a 250 thought with 4.30 diffy. Kinda same boat since I tow 11.5K. I just do not like all that commotion under the hood with tow haul. I personally like being a little more in control myself.
2112
baitboy wrote:
6200 lb. TT, 26 1/2 ft long. This is my loaded weight.
I towed a similar TT with my '97 4.6L without a problem. That one was a 4 speed and I just let it do its thing.
I currently tow a 9000lb FW with the same setup as yours except I have the 3.5L. Again, I never lock out 6th gear. I just put it in tow/haul and let it do its thing.
2011 Ford F-150 EcoBoost SuperCab Max Tow, 2084# Payload, 11,300# Tow,
Timbrens
2013 KZ Durango 2857
EcoBullet
Mitch
That's what I do also.
Me 1954, Nana 1954, Grandson 2003, Granddaughters 2005 & 2008
2014 Keystone Bullet Premier 22RBPR
2013 F-150 XLT Supercrew 4X4 Ecoboost Max Tow
APT
Tow/Haul lock out 6th gear is what I recommend and do with my similar power and weight combo.
2017 Subaru Outback 3.6R
MitchF150
Mitch
2013 F150 XLT 4x4 SuperCab Max Tow Egoboost 3.73 gears #7700 GVWR #1920 payload. 2019 Rockwood Mini Lite 2511S.
baitboy
rhagfo
What are you towing and how much weight?
baitboy
I have the 5L V8, 3.73 rear end with the tow package. Hope that helps.
trop-a-cal
What engine?
