Jan-24-2020 07:27 AM
Jan-25-2020 09:10 PM
Jan-25-2020 04:55 PM
Jan-25-2020 04:36 PM
Boomerweps wrote:
DO NOT GREASE the spring bar trailer frame mounts!
Jan-25-2020 10:13 AM
Jan-25-2020 07:31 AM
Jan-25-2020 06:45 AM
Jan-25-2020 05:17 AM
Jan-25-2020 04:37 AM
Jan-25-2020 04:12 AM
My question, is antisway bars are very noisy popping and squeaking with each turn, videos on u tube show this to be a quiet hitch. Height of brackets per instructions, truck lowered 1" front and back equally, bars are a little hard to put on even when raising the truck with trailer per instructions. Is this normal? Or do I have a problem with my installation?
Jan-24-2020 07:12 PM
b&rharmon wrote:
We purchased a very slightly used trailer, Forest River Evo T2460RL. I am working on getting my head wrapped around all the differences from our previous experiences, you can see below what we were camping with. Currently our tow vehicle is 2016 F150 with tow package.
One issue, weight distribution hitch. I purchased and installed Centerline TS hitch rated for 12,000 lbs. which is overkill for our trailer 7,800 dry weight, and installed per instructions.
Thank you for your input.
Jan-24-2020 04:53 PM
Jan-24-2020 03:28 PM
drsteve wrote:
I have that same hitch, the bars are rated for 800-1200 lb of tongue weight. Sounds like you are fine on the size. It is sometimes noisy at low speeds, according to the manual it is acceptable to use a light lubricant on the bar saddles.
My TT weighs about 6500 ready to roll, with roughly 900 lb of tongue weight. I have no problem at all with the hitch, it works well at all times. No sway, no weird instability, nice and solid. Does your TT tow OK?
Jan-24-2020 02:13 PM
Jan-24-2020 01:18 PM
