What campers
starcraft69
So the wife and I are looking for a new to us camper!! We looked at a few new ones but don't want to go bankrupt, so decided on just going newer than ours witch is a 98 caribou no slide. So after looking a little the wife would like to things witch will not be easy. She wants a slide and a dry bath!!!! yes I know not easy to find.
The caribou 11j has them both but stopped making them in 2003 we would like a little newer. We have a budget of about $20,000. So my question is what models out there have these to requirement's so I may began my search.
1. dry bath
2. slide out
Thank you guys and gals in advance.
2007 chevy 2500 HD 6.0 longbed
2015 Eagle HT 28.5 5th wheel
tucker the fishing dog
19 REPLIES 19
jimh406
If you liked the 950 but want a dry bath, take a look at the 1050 Tahoe.
starcraft69
jimh425 no we will be going dully if we make the switch to a bigger camper. I looked at a 08 Host 950 yesterday I liked it alot nice camper
jimh406
Not that I'm the weight police, but starcraft69 are you planning on trying to use your current truck?
Royals_Fan
AF 992 and Eagle Cap 995
starcraft69
Thank you guys the different model numbers in older models is exactly what I was looking for. I am surprised there are more dry baths than I thought.
cdbinns
Arctic Fox has a few models that have a slide and dry bath. 1150, 1140, 992
805gregg
We got a 2004 Lance 1071 it has both a dry bath and slide, for $13000, we love it, so much more room with the slide
2003 Dodge Quad Cab 3500 SRW LB Cummins diesel, Banks Six Gun, Banks exhaust, Mag hytec deep trans pan, and Diff cover. Buckstop bumper, Aerotanks 55gal tank, airbags, stableloads Bigwig stabilizer, 2003 Lance 1071 camper, solar and generator
bighatnohorse
FireGuard wrote:
I recommend looking at Lance, Arctic Fox, Eagle Cap, Host and Adventurer for starters.
There is a list under the stickys, but nothing like seeing them in person.
Dry bath and slide combinations mean that you will have a very heavy camper.
Don't go there. It will be expensive. Make sure that the DW understands that it will require a bigger truck or perhaps a lot of expensive upgrades to your current truck.
2021 Arctic Fox 1150
'15 F350 6.7 diesel dually long bed
Eagle Cap Owners
โ€œThe best lack all conviction, while the worst
Are full of passionate intensity."
-Yeats
FireGuard
There are numerous campers with a slide and dry bath, many with 2 and 3 slides.
It would help to narrow it down if you have an idea of how big you would want to go, tank capacities etc.
If you will be towing, the side door models are nice.
If you plan to pick the camper first and then get the appropriate truck, you will have many options.
Have fun with your search.
13Jeep Wrangler
07 Ragen 21FB
12 Yamaha Super Tenere
14 Suzuki DR 650
starcraft69
there you have what????????????????????????????
bka0721
And there we have it. Thank you starcraft69.
b
08 F550-4X4-CC-6.4L Dsl-206"WB GVWR17,950#
09 Lance 1191
1,560wSolar~10-6vGC2-1,160AmpH~Tri-Star-Two(2)60/MPPT~Xantrex 2000W
300wSolar~2-6vAGM-300AmpH~Tri-Star45/MPPT~Xantrex 1500W
16 BMW R1200GSW Adventure
16 KTM 500 EXC
06 Honda CRF450X
09 Haulmark Trlr
starcraft69
Bka0721 I posted I wasn't concerned about weight, that I was looking for the right camper!!!! I never once asked if my current truck would do the job or asking for help to find a model that would match my current truck so I am not concerned on other experience's. I simply asked What model campers have a slide and a dry bath?????? I am sorry if you felt I was new to TC and I am clueless But that is not the case. I am sure this tread will die now because it turned into the weight police thread. Witch is to bad because I was hoping for some knowledge and experience on different models not weight. Since it is so concerning to you, once I find the right camper If I do, and decide to purchase. I know that I will need to upgrade the truck to a 3500 or 4500 dully. but if I don't find what I am looking for then why would I buy a new truck?????????? I have been on here long enough that I should have posted that because of the weight police. MY BAD I thought a straight forward question could be answered.
Thank you to the guys that read the post and gave me some different models to look at. I hope I can find a few more than listed above.
bka0721
jefe 4x4 wrote:
Yes, with those two requirements, a 2 series truck is a stretch. Even with G rated tires, complete suspension upgrade, and a bigger anti sway bar it is iffy.
jefe
Jefe4X4, it is always disconcerning when an OP could care less about others experiences are with 2500 series trucks and possible campers and the impact on this series trucks. Then it seems obvious, by the OP's signature, he will be pulling a boat, in addition to a much heavier camper than he is currently carrying on his 2500 series truck. Personally I would be hesitant recommending any camper that would be a challenge for a 2500 series truck, irregardless to the needed upgrades to ensure it's ability to carry the weight and dubious on safety.
b
09 Lance 1191
16 KTM 500 EXC
06 Honda CRF450X
09 Haulmark Trlr
jefe_4x4
jefe
'01.5 Dodge 2500 4x4, CTD, Qcab, SB, NV5600, 241HD, 4.10's, Dana 70/TruTrac; Dana 80/ TruTrac, Spintec hub conversion, H.D. susp, 315/75R16's on 7.5" and 10" wide steel wheels, Vulcan big line, Warn M15K winch '98 Lance Lite 165s, 8' 6" X-cab, 200w Solar
