โJun-09-2019 05:21 AM
โSep-20-2020 07:55 AM
computermonkey wrote:JimK-NY wrote:
I cannot help you with your Chevy. I can tell you what worked with my 2018 Ram. I needed a new shark fin antenna in a better location. I could only find the antenna and appropriate wiring harness through the dealer. I did find the wiring specifics online. I had to remove the cover on the passenger side front window pillar to plug in the new wiring. I made a magnetic base that would work for attaching the new antenna to the hood. Before replacing the antenna, I had about 70% function. Afterwards that went to over 90%. I still lose signal in some locations when the truck is pointed exactly north.
Our 2013 has the same issue. I googled and found the part numbers and purchased the shark fin and wiring extension. Now my question is where do you run the wiring through the firewall?
Thanks,
โSep-19-2020 06:16 PM
flyte63 wrote:
While shopping for a 2020 F-250 we noticed two black parts n the top rear edge of the cab that appear to be The GPS Navigation Antenna and a Sirius XM antenna. Because of this location it seams like both would be severely impacted by a cab-over camper. Are there any 2020 Ford Super Duty owners who can chime in regarding real world experience with Nav and Sat radio performance when traveling with their camper?
Thanks!
โSep-19-2020 05:50 PM
โSep-19-2020 05:34 PM
โSep-19-2020 05:26 PM
โJul-27-2020 04:26 AM
โJul-25-2020 09:15 PM
โOct-22-2019 06:15 AM
Dennis58 wrote:
Hi
I have a Chevy, 2019 3500HD DRW Crew Cab and have been looking at the Lance 975 TC. For anyone with a similar setup does cabover section of the TC interfere with the reception of the SAT antenna?
Thanks
Dennis
โOct-22-2019 05:17 AM
โOct-21-2019 11:23 PM
โJun-11-2019 10:34 AM
โJun-10-2019 10:23 AM
โJun-10-2019 10:11 AM
โJun-10-2019 09:46 AM
On your new truck the access port for the antenna lead is in the dash behind the radio screen. I am unsure if a FAKRA connector will work with this and I have been afraid to pull the dash apart to check.
