โDec-02-2020 03:28 PM
โDec-04-2020 04:19 AM
JRscooby wrote:valhalla360 wrote:
You don't need a ton of torque at the crank shaft. Put it in 1st gear 4x4 low range and you can twist the axles off with a relatively weak motor.
And no even with rubber tires, it doesn't take that much to get it rolling.
In the '70s I had a few 427 GMCs (and a couple of Super Duty Fords, when SD implied 850 in VIN) I would pull out of quarry grossing 110,000 lbs. Step grade, or soft ground, put both boxes in 1. Might have to drive a stake in the ground to tell it was moving, but if your patient it will get there. But, once started downhill, would take a running automobile to pass.
โDec-04-2020 02:34 AM
โDec-03-2020 04:32 PM
valhalla360 wrote:NRALIFR wrote:
Not to be disagreeable, but I donโt think so. The torque required to get 374,000 pounds sitting on rubber tires rolling even on level ground has got to be huge. Did you see the truck as it started to pull? Even a diesel locomotive has to grunt hard to get a long string of cars moving, and those are sitting on steel wheels and rails that are level.
Donโt get me wrong, that truck wouldnโt be able to pull a load like that up any kind of grade for very long. I was just impressed that it was able to get it started without the road being littered with tranny parts. Who knows, maybe it did and they just cut that part out. :W
โDec-03-2020 04:24 PM
โDec-03-2020 03:20 PM
โDec-03-2020 03:19 PM
Grit dog wrote:
Need the โlikeโ button for spectras last post! Thatโs some serious wheelin for a big truck on stock suspension!
Idk about new trucks not being that tough. I think youโve already proved that wrong. Your white truck is still basically like new with how many miles.
Bottom line, โmostโ trucks are durable. The biggest variable is how theyโre taken care of...
โDec-03-2020 12:30 PM
โDec-03-2020 12:27 PM
noteven wrote:valhalla360 wrote:NRALIFR wrote:
Three-quarter ton, with a 350 CID V8. Thatโs pretty impressive even if it was just level ground.
Not really. On level ground, it doesn't take much to get a lot of weight rolling.
Now if they gave a 10sec 0-60 time, I would be impressed...or heck even climbing a 2% grade...but just getting it rolling on level ground isn't much of a test.
Dodge tows a logging truck up hill.
โDec-03-2020 10:39 AM
specta wrote:
I'm grateful that they don't build them like they used to.
โDec-03-2020 07:15 AM
jaycocreek wrote:
Had a 1974 GMC with the 454 for years..Awesome truck..
โDec-03-2020 07:12 AM
โDec-03-2020 07:02 AM
โDec-03-2020 05:56 AM
towpro wrote:
they don't make them like they used to
โDec-03-2020 05:33 AM
Eh theyโre pretty tough.
Redoing a 86 Camper Special right now. Super solid truck.
I love that old commercial btw. Wish ours was a 70s model!
โDec-03-2020 05:24 AM
