Blocks
Bigbird65
I use blocks under the stabilizing jacks and tongue jack. I don't like just throwing them in the pass through, pretty messy to do that.
The holder that I made for the 2 x 6 blocks is shown here. I made the 1/4" plywood spacers so the blocks will dry after a rain. The PVC pipe is glued in to the block that is mounted on the frame.
2017 RAM 1500 Quad Cab 5.7L Hemi, 8 speed 3.21
2018 Winnebago Minnie 2250DS
14 REPLIES 14
opnspaces
Navigator II
Navigator II
I like the idea thanks for sharing. As far as the cap, I would probably drill the blocks larger and just leave the cap on permanently.
Bigbird65
RVcircus wrote:
Good idea. I'd personally go with steel and bolts over PVC and zip ties, but I like it. Thanks for sharing!
There really has been a lot of concern over my using the zip ties. Yes, they may not be UV rated but I have used them in other outdoor applications for many years with no breakage problems. The two on the trailer have traveled over 6000 miles in a year and a half without any sign of deterioration. I did add two new ones and will replace all 4 at the first sign of deterioration. I have plenty of these heavy duty zip ties in the trailer.
The only thing I have to watch is to not press the PVC cap on too much. It can be a bear to twist off. Actually the only reason that I use the cap is to keep rain out of the PVC pipe. Glad you folks liked the block idea. Post some photos of your new block installation.
I'll post some new DIY ideas when I have a chance.
RVcircus
2000 KZ Sportsman 2505 (overhauled & upgraded 2014)
2016 Chevy Express 3500 15 passanger van
6 humans, 2 cats, and a dog
Visit our blog at www.ROWLESmade.com
Our trailer re-build thread
pawpaw47
Great idea! I think I'll have to "borrow" it.
2015 Starcraft Autumn Ridge 329BHU
2015 Starcraft AR-One 18QB
2014 GMC w/6.2L & max tow pkge.
Tango__AE7UI
Even better is to use the large radiator hose clamps.
They are stainless steel and will outlast the zip tys.
2007 Tango 2660RKS Fifth Wheel, 2006 Chevy D/A 3500 with service body,
Pass42
Find the BLACK TY-RAPS... they are UV resistant for outdoor use
2017 Montana High Country 375FL
2015 Ram 2500 Heavy Duty, Cummins 6.7, factory tow package, factory snow plow prep package
Bigbird65
full-timer wrote:
A couple of u bolts will do the trick.
Update: 4 straps.
nineoaks2004
I just throw them in the back of the pick up, I will reset when I get home anyway.. It is a good idea tho..
By the time you learn the rules of life
You're to old to play the game
Tachdriver
Nice idea!!!!
MountainAirMan
Excellent idea. I just pack mine in a milk crate in bed of truck.
I'd think the zip ties will certainly last a season. Give you time to decide if you definitely want to keep them there before making it permanent.:h
Lyle (the other one)
full-timer
An Indian and a Gypsy
Joe and Nancy
2002 34 foot Georgetown double slide Ford V-10
towing 2004 Chevrolet Cavalier 4 Down
Lynnmor
The white ties are not UV resistant and will break. I do like the concept.
Bigbird65
Old-Biscuit wrote:
Nice! Handy and organized. Great idea!
Might want to rethink using those zip ties to secure platform.
Sun will make them brittle in no time......snap while in transit. Blocks/platform bouncing down highway--------YIKES!
Bolted to tongue or metal straps.
......or maybe 2 additional straps.
Old-Biscuit
