โAug-10-2016 05:44 PM
โAug-11-2016 05:27 PM
myredracer wrote:
Another solution is that Southco makes a cabinet latch with a built-in microswitch that they call the "grabber".
โAug-11-2016 04:46 PM
โAug-11-2016 11:53 AM
myredracer wrote:
Another solution is that Southco makes a cabinet latch with a built-in microswitch that they call the "grabber". I just installed one on our pantry door for LED lighting I installed inside. These catches come in 3, 5 & 10 lb. rating - the 10 lb is what I bought and is too strong - 5 lbs would be better.
Southco also makes them without a microswitch and are an excellent upgrade for the standard flimsy roller catches that are commonplace in RVs (which don't always work that well). These latches, less microswitch, are also available from RV Designer and JR Products.
โAug-11-2016 09:31 AM
โAug-11-2016 07:56 AM
โAug-11-2016 07:25 AM
โAug-11-2016 06:42 AM
GordonThree wrote:
AUwing:
I'm using these to light my cabinets and closet. Snap action microswitch with a roller arm.
http://www.mpja.com/SPDT-Snap-Switch-with-Roller-4A/productinfo/16314+SW
There's 3 terminals labeled COM, NO and NC... NO = normally open, will be closed when the switch is pressed in. NC = normally closed, will be open when the switch is pressed in. COMmon is the other side of the switch.
4-amp rated contacts is good for ~40 watts of LEDs.
โAug-10-2016 05:59 PM
โAug-10-2016 05:55 PM
