โJul-02-2015 06:30 PM
โJul-16-2015 03:46 AM
โJul-15-2015 04:28 PM
Although I would commend the dealer and yourself for extra bracing, etc. I would also be slightly concerned with the affect of this bracing.
1) if that tank can shift around it may eventually wear through at any point of rubbing on those angle brackets or any little bumps/bolts on the brackets.. Looks like the dealer did a good job and used wide brackets but I sure wouldn't want to take responsibility for say a 1" angle iron "helping" the situation instead of making it worse.
2) Personally, I would never draw water from the bottom of any tank.. Too much sediment which will inevitably get into your pump and system and cause who-knows-what problems further down the line (pun intended).
To each their own but there could be some downside to these repairs.
Posted By: minnow on 07/15/15 03:55pm
Whenever I read the posts on this subject, most replies are the same;
why not more bracing under the tank.
When I saw the "L" brackets on my first 5er, my thoughts were the same. Talked to dealer and he said about the same thing
Thanks for the uplifting words of support to the OP. Geesh.
โJul-15-2015 12:55 PM
โJul-15-2015 12:33 PM
SoundGuy wrote:Bmach wrote:
I have never traveled with anything in my tanks, except a couple of gallons of water in the black tank.
That's unfortunate as that then means you're not able to take advantage of one of the great advantages offered by owning a trailer you can get into by simply opening the door - using the facilities, anywhere, anytime. It also means that when you do want to use the system you first have to re-pressurize it ... can't imagine going through that when I can simply do it once at the beginning of the season. :h
โJul-15-2015 09:49 AM
โJul-15-2015 09:16 AM
โJul-06-2015 01:32 PM
SoundGuy wrote:
... Our current Coachmen Freedom Express has an open underbelly so the first time I filled the FW tank and looked underneath the trailer this is what I saw ...
I had my dealer install steel supports under the tank and once that was done I installed a T on the drain port ...
โJul-06-2015 07:19 AM
SoundGuy wrote:3oaks wrote:
There are advantages of a sealed underbelly, However there is one major disadvantage of a sealed underbelly, you can not inspect things under there and are unaware of potential problems before they self destruct. That is a concern of mine with the new TT that I have on order. ๐
A legitimate concern IMO. Our TrailCruiser hybrid had an enclosed underbelly which I had to open when I discovered it sagging badly because the pump hose connection to the tank hadn't been adequately tightened during assembly and was leaking so badly water eventually sagged the underbelly. Our KZ Spree TT also had an enclosed underbelly which I also had to open up for maintenance purposes. Our current Coachmen Freedom Express has an open underbelly so the first time I filled the FW tank and looked underneath the trailer this is what I saw - a tank that sagged so badly the pump was unable to draw most of the water out of the tank. It didn't seem like it was about to fall off but this installation sure wasn't reassuring -
I had my dealer install steel supports under the tank and once that was done I installed a T on the drain port and moved the pump draw line from the sidewall of the tank down to that lower port so I can now draw ALL the water out of the tank. I also now have full confidence of being able to travel with a full tank if I wish with no concerns it will ever fall off the trailer. :B
We camp from late March / early April through to late Oct / early Nov and not having an enclosed underbelly hasn't made a bit of difference in terms of being able to keep the trailer warm inside so given what I know now I have to say I much prefer a trailer with an open underbelly.
โJul-06-2015 03:29 AM
โJul-05-2015 06:15 AM
โJul-05-2015 05:47 AM
Heap64 wrote:
I hope this was a fluke but it sounds like very poor design.
โJul-03-2015 09:53 PM
โJul-03-2015 07:42 PM
โJul-03-2015 07:16 PM
โJul-03-2015 06:56 PM
