Ceramic heater to heat hydraulics in battery compartment?
Don_A_L
Hi
Need to pickup my fifth wheel in KC on Thursday. Temps over night Wednesday to be in single digits. I was told by Lippert that it's not a good idea to try and use the front jacks at temps below 32. Ditto for the slides. I was thinking about heating the front compartment where the hydraulic pump and tank is, with a ceramic heater. The 6 volt batteries are in there also, in a box with a vent hose. Any concern with battery fumes
and the heater? Not sleeping in trailer.
How low is too low to open and close slides. Will still have some cold nights driving to Boulder City, Nv.
2014 DRV Tradition.
Don
17 REPLIES 17
TXiceman
Don A L wrote:
Hi
Don
Sounds like Lippert needs t redesign their hydraulics. They should work if they designed the system properly at 32 degF. Now 0 degF might be a problem.
Ken
Amateur Radio Operator.
2023 Cougar 22MLS, toted with a 2022, F150, 3.5L EcoBoost, Crewcab, Max Tow, FORMER Full Time RVer. Travel with a standard schnauzer and a Timneh African Gray parrot
bpounds
Lippert is just lawyered up and being overly cautious. And considering their hydraulics leak if you give them a dirty look, it isn't surprising. The seals will be stiff, and may leak a little, but like everyone said it should be fine.
2006 F250 Diesel
2011 Keystone Cougar 278RKSWE Fiver
Miramichi_cruis
Living in Canada...we just use things unless its frozen solid. Any hydraulic or substitute fluid will meet NA DOT spec and may be sluggish but will still pump. As for you batteries, just draw from them to warm them up and the voltage will stabilize. We do that with cars here...just turn ignition on for 2 mis then start, you will increase amperage. If you plan on heating and are charging the batteries, as already stated don't put the heater in a closed compartment. I would recommend ducting the heat in or venting the compartment well. You only have to bring the battery to just above freezing to get more than 50% back.
Steph and Eden
Miramichi, NB
john_bet
Are you not going to move your truck in that kind of weather? It's the same type of fluid. Food for thought.
2018 Ram 3500 SRW CC LB 6.7L Cummins Auto 3.42 gears
2018 Grand Design 337RLS
Allworth
Do you see Highway Construction and Snow Clearing working in cold weather?? Same hydraulics, just bigger.
Formerly posting as "littleblackdog"
Martha, Allen, & Blackjack
2006 Chevy 3500 D/A LB SRW, RVND 7710
Previously: 2008 Titanium 30E35SA. Currently no trailer due to age & mobility problems. Very sad!
"Real Jeeps have round headlights"
kennethwooster
Don't worry about it. Modern day hyds should work in our cold weather.. Sounds like some of Lipperts crazy talk. Just go for it. You should be fine.
kenneth wooster- retired farmer. Biblical History Teacher in public HS, and substitute teacher.
wife Diana-adult probation officer, now retired.
31KSLS Full Body paint Cameo
Ford F350 2014 DRW 4X4 King Ranch.
20K B&W Puck mount hitch
Don_A_L
Thanks for the insight. I think I will just move the landing jacks down and up a bit, then go ahead and hook up. I have the slides in now and don't need to open up until I get to Foss, Ok. for the night.
Southwest here we come!
Ivylog
What's next... you should not use your slides/jack more than one time a day??? I would not worry about using at any temp above 0.
Upgraded with a 08 HR Navigator 45โ€™...
WyoTraveler
I don't know what fluid is in your Lippert tank. my Lippert tank has power steering fluid. (definitly not heavy hydraulic fluid. I believe manual says Mercon) My tank is mounted beneath my door step under my coach totally exposed to the outside elements. My slide and jacks operate OK in cold temps. Check your model # and fluid they use in yours. I assume you have a new unit. Maybe some of the older units use heavier hydraulic fluid.
mich800
So there are no 4 season rv's with Lippert products? Seems like an odd restriction.
rockintom
I think you need to revisit the fact about using the jacks and slides in cold weather. Lippert systems use Dexron III ATF. One of the reasons is that the viscosity doesn't change readily until you get in VERY temps. Temps so low you wouldn't want to be in a RV for any reason. Dexron starts getting thick and gooey at about -60*F. Operating the system in -20*F and slightly lower shouldn't be a problem. Ice and snow build up may be another story. rockin'
Rockintom
'12 Excel Limited GKE 33 ft., trailer named "Charm"
'14 1 ton Chevy DRW D/A Reese 20K hitch Fold-A-Cover bedcover - truck named "Bullet" Fulltiming since 2005
christopherglen
The rams are going to be at or below freezing, no matter what you do to warm the oil in the tank, as soon as you start the pump the sub-freezing oil already in the rams will be forced back into the tank, missing and undoing all the heating you just did.
Other then water contamination of the oil (and the ice that it makes) - the only other thing to worry about is cavitation of the pump. I doubt that is much of an issue at the low flow rates of out pumps until it gets far below freezing.
I for one set up and tear down in the winter, and overnight temps are well below 32.
2007 Chevrolet 3500 CC/LB Duramax/Dually 4X4 Mine r4tech, Reese Signature Series 18k +slider, duratrac, Titan 62 gallon, diamond eye, Cheetah 64
2011 Keystone Fusion 405 TrailAir & Triglide, Centerpoint, gen-turi, 3 PVX-840T, XANTREX FREEDOM SW3012, G614
TucsonJim
I'd be hesitant to put the heater by the batteries. I'm sure you'll be plugged in to use the heater, which means the converter will be charging the batteries. A byproduct of charging the batteries is hydrogen gas which is very flammable. If the H2 gets to a concentration of 4% or more in air, you can have ignition.
If you must put a heater in the battery compartment, make sure your batteries are in containers that are properly ventilated to the outside of the FW.
2016 Ford F350 Turbo Diesel SRW 4x4
2017 Grand Design Reflection 297RSTS
2013 Ford F350 Turbo Diesel SRW 4x4 (Destroyed by fire - 8/29/16)
2014 Grand Design Reflection 337RLS (Destroyed by fire - 8/29/16)
Trackrig
J&L Rivera wrote:
The hydro being cold shouldn't be an issue either. I've never seen an excavator or dozer in a heated garage to start and run thru a winter.
Though, getting the tank and pump warmed up sure aint gonna hurt it none.
I agree with Rivera - the hydraulics may work a little slow, but they should definitely work. The heat won't hurt, but the heat will only heat the pump and reservoir, but the heat won't get out the hyd. lines and the cylinders until you've run it some. I'd take up the landing gear first because there won't be a lot of strain in lifting them and that will get the warm oil part way you to slide cylinders. Also the later in the day might be better if the days are warming up nicely.
Bill
