Sep-05-2013 06:10 AM
Sep-07-2013 08:24 AM
2014 RAM 3500 Diesel 4x4 Dually long bed. B&W RVK3600 hitch • 2015 Crossroads Elevation Homestead Toy Hauler ("The Taj Mahauler") • <\br >Toys:
Sep-07-2013 08:11 AM
B.O. Plenty wrote:mpfireman wrote:Pure BALONEY! Obviously you have never compared a ST tire and a LT tire side by side. The sidewalls on an ST tire are like a bicycle tire in comparison. The only reason they are on there when new is because they are CHEAP and the manufacturers don't want you to know that...Stop drinking the Kool Aide! If you ever ran a set of LT tires on your rig you would never go back.
ST tires are made with stiffer and additional plies in the side walls, thus when turning ,your trailer's 2nd or 3rd axle being stationary causes these other tires to slide around corners. LT tires lack these added plies. But again many RV owners have switched from the ST tires to the LT tires. It's your rig, so you have to make that choice. ST tires also contain additional rubber compounds that are designed to withstand long exposure to the sun, thus they say, less sidewall cracking.
B.O.
Sep-07-2013 07:22 AM
lincster wrote:
Typical salesman, doesn't have a clue.
With LT tires, you won't need the warranty for tire issues cause you won't have them.
Sep-07-2013 07:21 AM
joebedford wrote:
So what IS the difference between a 32lb ST235/80R-16 and a 60lb LT235/85R-16? Yes, the truck tire is slightly bigger but that doesn't account for nearly double the weight.
Sep-07-2013 07:14 AM
CapriRacer wrote:So what IS the difference between a 32lb ST235/80R-16 and a 60lb LT235/85R-16? Yes, the truck tire is slightly bigger but that doesn't account for nearly double the weight.
I have an idea. Why not ask someone who designs tires what he thinks?
And the answer is that for practical purposes, there is no difference in the casings between an ST tire and an LT tire.
Sep-07-2013 05:25 AM
B.O.
Sep-06-2013 03:37 PM
Sep-06-2013 09:47 AM
B.O.
Sep-06-2013 08:39 AM
TucsonJim wrote:
Ric - I'm sure you meant ST, not LT???
Sep-06-2013 08:32 AM
Sep-06-2013 08:23 AM
joebedford wrote:B.O. Plenty wrote:X2mpfireman wrote:Pure BALONEY! Obviously you have never compared a ST tire and a LT tire side by side. The sidewalls on an ST tire are like a bicycle tire in comparison. The only reason they are on there when new is because they are CHEAP and the manufacturers don't want you to know that...Stop drinking the Kool Aide! If you ever ran a set of LT tires on your rig you would never go back.
B.O.
Sep-06-2013 05:01 AM
B.O.
Sep-05-2013 07:25 PM
Sep-05-2013 01:18 PM
TucsonJim wrote:
One thing I never realized about my "ST" tires is that they are rated for 65mph max. In Arizona, our interstate speed limit is usually 75mph. However, with that said, there always appears to be a vehicle cruising down the highway at something less than 65. I usually drive my rig at 64-65mph, but on occasion, I've had to bump it up to 70 while passing so I don't impede traffic. I get a little nervous taking those ST tires up to 70 for the minute or so that it takes to pass.
And while I'm on the subject, a pet peeve of mine is when I ride behind a slower vehicle for quite a while, and finally make up my mind to pass. It seems that quite often, the said vehicle must not like getting passed by a big truck and FW, and decides to speed up once I'm in the passing lane. Or worse, start pacing my speed so I can't get back over!
