Ford F-250 Setting Electric Trailer Brakes...
karldavidson
Does anyone know how to set the electric brakes on a RV? I drive a F-250 Ford.
My RV weight is 9800 lbs. The dealer said to set it a three. However, this setting seems not to brake properly.
I bet a man at a RV park with the identical RV. He said he set his for 7.5 dry conditions and 8 for wet.
I've read the instruction from Ford. Doesn't make a lot of sense.
If it sounds like I'm confused, I am.
Thanks for any help.
Karl Davidson
Karl and Cassie Davidson
Texas
"Making the World a Little Better Every Day"
13 REPLIES 13
SuperDutyMan
Kenc_AL wrote:
Jack_Diane_Freedom wrote:
I have a 2011 F-250 with the IBC. I set it at 9 and forget it. Towing 8000lb trailer. Remember these do not work like an aftermarket controller. They apply the brake proportionally very smoothly as you press the brake pedal and is integrated with the ABS of the truck. It does not 'grab' at all. Nice and smooth. It will only go to full 9 setting (or where ever you set it) only if you hammer the brakes and that is when you want the most braking.
X2 except 11,000 lb. Best controller I have ever had.
2011 Palomino Sabre 31RETS,5th Wheel,Triple Slide,4000W Onan Genset
2006 Super Duty,XLT, V10, 6 Speed, 4.10, Tow Command, Tow Pkg. 4X4,Dual Exhaust,K&N,Reese 15K,Air Bags
Kenc_AL
Jack_Diane_Free
lenr
Start at 8. Go for same brake petal feel as when not towing--increase if having to push hard; decrease if trailer wheels lock or seems usually jerky. Ford brake controller supplies less voltage under 11 mph so test on a safe road at 20 mph. Manually activate fully to test for lock up. You should definately feel a slow down when manually activating at full brake. You don't want trailer wheel lockup on any solid surface--decrease if it locks.
mikeh449
on the controller on you dash will be a plus and minus buttons to add more gain push the plus it will make the trailer stop harder the minus works to lessen the braking power
karldavidson
WoodGlue wrote:
Which brake controller are you using, or is it integrated?
WoodGlue
My 250 is a 2013 and the controller is OEM.
Texas
laknox
To the OP, remember that, as you're adjusting your brakes, if you hit dirt, sand or gravel, your wheels are likely to lock up, so be aware of the surface as you drive. I know that I'll turn mine down driving in to our boondock camp site after leaving the pavement. Biggest issue is remembering to turn the gain back up after hitting the pavement, but the first downhill usually does the trick. 🙂
Lyle
2017 KZ Durango 1500 D277RLT
1936 John Deere Model A
dahkota
We have ours set for 7-8 depending on conditions - they came OEM with our F250.
2015 Jeep Willys Wrangler
2014 Fleetwood Bounder 33C
States camped: all but Hawaii
more than 1700 days on the road
brirene
Assuming you have the built in brake controller of your truck is later than an'05. With this controller the trailer brakes won't necessarily grab the way add on controllers do. Braking is much smoother.
Jayco Designer 30 RKS Medallion pkg, Trail Air pin
'05 F350 6.0 PSD CC 4x4 DRW LB B&W Companion, Edge Insight
“Certainly, travel is more than the seeing of sights; it is a change that goes on, deep and permanent, in the ideas of living." Miriam Beard
WoodGlue
WoodGlue
2002 Land Rover Discovery II
2014 Lance 1685 - Loaded - 4 Seasons - Solar - 2 AGM's
When Hell Freezes Over - I'll Camp There Too!
Lance Travel Trailer Info - Lance 1685 Travel Trailer - Lance 1575 Trailer
RoyF
Like TxTiger said, use a setting that stops well without locking up. Go go a parking lot or someplace with no traffic. Creeping along at 3 or 4 mph, apply trailer brakes using the manual switch on your controller. If brakes lock up then use a lower setting and try again. Use the highest setting that does not lock the trailer brakes.
Brakes wear over time, so we ought to retest and reset our controllers now and then.
sail2liv
First maybe an inspection of brakes and adjustment .... with that correct is just a matter of setting the controller to give you desired effect.....
Good luck....on my 2500 hd I set at 5 for 8500 lb 5 er.....
TxTiger
Your brake controller should have some instructions. If you don't have an instruction book check on the web. On mine, I just rotated the sensitivity knob until the brakes stopped well but didn't "lock-up".
2000 F250, 7.3 PSD, 6 speed manual, CC, SB
2013 Northstar TC800
