Sep-05-2016 12:01 PM
Sep-06-2016 09:30 AM
clev wrote:The 15.5k you're referring to is defined as AXLE WEIGHT, not "tow(ed) weight". 15.5k of AXLE WEIGHT plus 3k of pin weight equals a trailer that weighs 18.5k (15.5k + 3k = 18.5).
. . . My position, and that of Curt who is a major hitch manufacturer, is that the 'towed' weight of the trailer is everything in and on the trailer, 'minus' the pin weight, because the truck is not towing the pin weight. So, with my example, the 18.5k pound trailer has a pin of 3k, and a 'towed' weight of 15.5 k. That has no effect on gcwr, and I know that.
Sep-06-2016 05:20 AM
Sep-06-2016 03:32 AM
cmeade wrote:clev wrote:. The truck will be towing 18,500 trailer not 15,500 trailer!!
Thanks, KD4. I guess my biggest confusion was/is 'Trailer Weight". I know that trailer weight is what it weighs on a scale but I 'think' that is different than max tow weight. In my example, the trailer has a pin weight of 3k pounds and when that weight is transferred to the truck, the trailer, sitting on a scale would weigh 15.5k pounds, which is what the truck will actually be pulling. The 3k pin weight just gets added to the GVW, which is still well within limits. Anyway, do you see my confusion?
Sep-05-2016 09:07 PM
Sep-05-2016 08:08 PM
clev wrote:
Wil, I've explained as best I can and I also read the Trailer Life article to which you reference. I give up. But, if you go back through and read my responses, perhaps you'll see that the horse has been dead a long time.
Sep-05-2016 07:41 PM
Sep-05-2016 07:26 PM
clev wrote:
Wilber, maybe I wasn't clear. I am familiar with gcwr and know it is the total weight of the truck and the trailer with all passengers, equipment, and fluids. I've said that since the beginning and yes, I'll be a little over gcwr recommendations. It's the towed weight that we disagree on. And no, I have not said you can pull any weight. According to the specs for my truck, it has a payload capacity of 3790 pounds (directly from Ford) and it can tow 15,700 pounds; max, that's it. My position, and that of Curt who is a major hitch manufacturer, is that the 'towed' weight of the trailer is everything in and on the trailer, 'minus' the pin weight, because the truck is not towing the pin weight. So, with my example, the 18.5k pound trailer has a pin of 3k, and a 'towed' weight of 15.5 k. That has no effect on gcwr, and I know that.
Sep-05-2016 07:16 PM
Beverley&Ken wrote:
Quote " Fact: the trucks specs will allow up to 3700 pounds on the rear axle. I'm good on everything except gcwr. I'll have to load very carefully. "
Is that 3700 pounds the rear axle rating , which would include the weight of the truck,(box, fuel, suspension etc, hitch and cargo) or is it the cargo carrying capacity not counting whats all ready part of the truck?
Ken
Sep-05-2016 07:08 PM
Sep-05-2016 06:50 PM
CALandLIN wrote:
I think the best way to look at your weights is to place a safety zone on them. The truck’s GVWR is 11.5K. That’s it’s maximum safe weight allowance from it’s manufacturer. Anything above that is going to be speculative. Same thing with the GVWR for the trailer and the entire rig’s GCWR.
Sep-05-2016 06:46 PM
Sep-05-2016 06:31 PM
clev wrote:
Hi wilber; no, I'm not saying it, I'm quoting it from Curt's web site but I do agree with them because it makes sense to me. If the truck is within specs and carrying part of the trailer weight, then it is towing the remaining weight. And I think the word 'towing' and max towing weight is being misinterpreted. I interpret it as the truck being able to carry a certain amount of weight, AND tow a certain weight. As a radical example, if I dropped a 3000 pound weight in the bed of my truck, I could drive around all day with that weight and still have the capability of towing/hauling 15700 pounds. And you are correct on the gcwr. I'm not sure what my status will be until I get the trailer and get it weighed.
Here are the main test methods trucks would be measured on as per J2807:
Cooling capability on a long highway upgrade modeled on the Davis Dam grade on Arizona SR 68;
Launch and acceleration performance on a level road and a 12 percent upgrade;
Combined handling performance – understeer and trailer sway;
Combined braking performance – stopping distance and parking brake-hold on grade; and
Structural performance for the vehicle and hitch or hitch receiver.
New calculations for trailer weight ratings: In addition to the performance standards, SAE J2807 also uses a specific set of assumptions to calculate maximum trailer weight ratings:
Sep-05-2016 05:58 PM
clev wrote:I reality your truck is pulling the whole load, as in, the truck and trailer combo called GCVW. The engine,trans,rearend has to work very hard to move the kind of weight you are considering. The more weight the harder the work.
Sep-05-2016 04:47 PM
Sep-05-2016 04:34 PM
SanMarMor wrote:
Trailer weight is trailer weight. Part is sitting on the axles, part is sitting on the hitch. But you're pulling, and stopping, the full trailer weight.
Mark
