Sep-17-2015 06:10 PM
Sep-19-2015 08:40 AM
Sep-18-2015 09:08 AM
VTLee wrote:
I have a 2010 Cougar 276RLS with two 12 volt batteries that will discharge in two or three days if I am running the frig on gas. This is just setting with no other use such as lights, pump, slide etc. Just the phantom draws and the frig. I have checked the batteries and they will stay charged for weeks when I use the disconnect switch. Does the frig draw that much juice. It is a two way Dometic DM2652 not a three way. What am I missing or is this normal.
Sep-18-2015 09:05 AM
csamayfield55 wrote:
I would bet your fridge is in a slider and it has an electric "12 volt" fan between the upper and lower coils.
Sep-18-2015 08:05 AM
SoundGuy wrote:eb145 wrote:
The Dometic DM2652 has a climate control system that uses 12V DC power to run heaters on the door strip to evaporate water that condenses on the door strips. Make sure the climate control switch is turned off to reduce battery usage.
Dometic fridge manual
The Dometic manual for this fridge may show a climate control switch but my own DM2652 definitely does NOT have a switch so I added my own.
Dometic DM2652 DIY Climate Control Switch
Sep-17-2015 10:09 PM
Sep-17-2015 09:20 PM
Sep-17-2015 08:45 PM
Sep-17-2015 06:35 PM
Sep-17-2015 06:32 PM
Sep-17-2015 06:31 PM
Sep-17-2015 06:27 PM
Sep-17-2015 06:19 PM
Sep-17-2015 06:14 PM
