How much can the landing gears lift?
aruba
Hi,
I am temporarily parked on my inclined drive way to ready the FW for the weekend. The fridge will not start because the front end of the FW is not level with the rear. Can the landing gears lift the weight of my F350 still attached to the FW in order for me to bring the front end of the FW level?
25 REPLIES 25
ependydad
bpounds wrote:
I definitely would not lift the truck with the landing gear. I doubt it would have the power to do it anyway.
And I'll bet that is not the reason your fridge isn't firing off.
X2
2017 Spartan 1245 by Prime Time
2018 Ram 3500 Crew Cab DRW w/ 4.10 gears and 8' bed
FW Hitch: TrailerSaver TS3
Learn to RV- learn about RVing - Towing Planner Calculators - Family Fulltiming FB page
AZ_T_T
The owners manual for my FW fridge says it can be upto 6* off of level front to back and upto 3* off of level side to side, so maybe you don't need to lift the truck.
AZ T&T
2012 Jayco Eagle Super Lite 29.5RKS
2011 Chevy 2500 HD 4x4 Duramax
B&W Companion Hitch - Firestone Ride-Rite Air Bags
Honda EU2000i Generator
dbbls
Yea, it'll do it. I see trucks hanging from 5th wheels all the time. That's the way I rotate my duallie's tires.
2011 F-350 CC Lariat 4X4 Dually Diesel
2012 Big Country 3450TS 5th Wheel
Allworth
Don't do it. Unhook.
You are likely to shear a roll pin that protects the motor from overload/overtravel.
Formerly posting as "littleblackdog"
Martha, Allen, & Blackjack
2006 Chevy 3500 D/A LB SRW, RVND 7710
Previously: 2008 Titanium 30E35SA. Currently no trailer due to age & mobility problems. Very sad!
"Real Jeeps have round headlights"
goducks10
Not sure how your cutoff is for the motor but mine is not like the slide or the TT tongue jack. I'm guessing your 5'er jacks are like most and when you hit the bottom or the top and hold it too long it will blow the inline fuse. Essentially you wouldn't be able to lift much more than the 5'er and you'd blow the fuse. Or worse the motor.
joebedford
Nomad II
Nomad II
I was able to lift the front end of my previous rig about 1 foot to accommodate a sloping driveway. Not attached to the truck of course.
Buckeye_Chuck
DON'T DO IT! The design intent of your landing gear did not include lifting your truck. Just unhook it. It's not that hard.
-BC-
2012 F250 Lariat 6.5ft. bed, 6.2L, 3:73 Gears
2013 Sabre 33CKTS-6
45Ricochet
Maybe you can drive your rear axle onto some blocks (ramps) will help.
Not sure how much of a incline your talking about.
2015 Tiffin Phaeton Cummins ISL, Allison 3000, 45K GCWR
10KW Onan, Magnum Pure Sine Wave Inverter
2015 GMC Canyon Toad
Previous camping rig
06 Ram 3500 CC LB Laramie 4x4 Dually 5.9 Cummins Smarty Jr 48RE Jacobs brake
06 Grand Junction 15500 GVWR 3200 pin
bpounds
2006 F250 Diesel
2011 Keystone Cougar 278RKSWE Fiver
Housted
I would not do it more than a couple of inches above the loaded level. The frame of the 5th is probably not designed for that kind of load.
Housted
2019 Forrest River Forrester 3051S 2014 Honda CRV toad.
1000 W Solar, converted to 50 amp
400 Amps of LiFePO4,3000 Watt Inverter, Refer converted with JC refrigeration unit, Sofa replaced with 2 swivel chairs, over cab bed converted to TV mount and storage
donn0128
I would not! The landing gear has decent capacity, but not that much. Why not unhitch from the truck.
