Apr-06-2014 05:22 PM
Apr-07-2014 03:49 AM
BB_TX wrote:
The payload ratings for the trucks keep rising every year. The new SRW trucks can support weights not considered even just a few years ago. I know there are many on the Montana Owners Club forum that do tow the larger Montanas with SRWs and say the weight is within their new truck ratings. And they say stability is no problem either.
I pull a 35' Montana with my 2012 F350 SRW. It is within the weight and tow ratings. It tows the 5er great and stability is also great, even in strong cross winds. And pulls Colorado mountain passes with little effort.
Apr-07-2014 01:01 AM
Apr-06-2014 10:29 PM
Apr-06-2014 09:04 PM
2RR2NV wrote:
Hi ya all.
My wife and I will be purchasing our first 5th wheel in the 2016. Yeah yeah, you're probably like... WTH are you asking NOW when it's so far away. Well, we want to get a truck that will fit our needs without having to upgrade every 2, 3, or 4 years because we wanted to get a "bigger/better" 5th wheel down the road. we are looking at a Ram3500 4x4 CC auto CTD. But can't decide on whether to get an SRW or DRW. I "think" we should have a DRW to pull a 38' Montana since it weighs so much. Am I wrong and that an SRW will pull it too just fine? another issue we have is that if we want to go hunting up on the Plains, there are plenty of spots where a dually is gonna have problems compared to an SRW. soooo what should we do? DRW or SRW.
if possible, please give thoughts on why or why not, one or the other, will work or not, please.
on a sidenote, we intend to get the truck late 2015 and then go buy the 5er spring of 2016.
also, more time will give me more time to do more research before the purchase.
thank you ahead of time.
Scot "Z" a.k.a. TOTAL newb! 🙂
Apr-06-2014 08:58 PM
Apr-06-2014 08:51 PM
Apr-06-2014 08:31 PM
Apr-06-2014 08:07 PM
Apr-06-2014 07:54 PM
Apr-06-2014 06:39 PM
Apr-06-2014 06:36 PM
therink wrote:
My 2 cents says:
How much will you be towing? Full time or part time?
What is the gvwr of the fiver you have in mind?
If gvwr is under around 13500, SRW would be ok. More that matters is how much will you be towing? If full time, then no question DRW. If the truck will also be a daily driver, then you will need to decide using weight of fiver and pin as main factor.
My 1 ton SRW tows my 12k fiver with no issues and DRW would be overkill in my case. I also drive it daily for work and tow about 2k year.
Apr-06-2014 06:04 PM
Apr-06-2014 06:01 PM
Apr-06-2014 06:00 PM
Apr-06-2014 05:49 PM
2RR2NV wrote:While both trucks can PULL a similar load, the huge difference is the payload (ie the weight the truck can carry).
Hi ya all.
My wife and I will be purchasing our first 5th wheel in the 2016. Yeah yeah, you're probably like... WTH are you asking NOW when it's so far away. Well, we want to get a truck that will fit our needs without having to upgrade every 2, 3, or 4 years because we wanted to get a "bigger/better" 5th wheel down the road. we are looking at a Ram3500 4x4 CC auto CTD. But can't decide on whether to get an SRW or DRW. I "think" we should have a DRW to pull a 38' Montana since it weighs so much. Am I wrong and that an SRW will pull it too just fine? ..................
