Pulling Power
grahampconrad
I have a 2012 new off the lot Big Country. I did not have a truck at all, so i think i have a say. First off i did some research and found that the 38 ft. ran at 17000 lbs. So i bought a brand new 2011 trailer kit GMC SIERRA 3500 HD long box 4 wheel drive crew cab and put a 16000k hitch by Reese. No dully just 4 wheels. My wife and I fill it to the 9s. It rides just fine. 4 wheels are a whole lot cheaper than a dully and less repairs. You have to think parking space, can wife drive that big a truck i do not think so, mine would kick me around the block. You do not need a Dully.
G Conrad
Richmond, BC
2012 Heartland Big Country 38 Ft. 5th Wheel
63 REPLIES 63
spud1957
wandering1 wrote:
If you get the camper and towing options on the 3/4 ton then you get the larger 1 ton brakes and suspension system.
Not sure what manufacturer that applies to but it sure isn't Ford. All you get with Ford' camper package is an overload spring and torsion bar.
2018 F350 6.7 4x4 CCSB
2022 GD Reflection 337 RLS
Cummins12V98
Bamaman1 wrote:
It's doubtful that your trailer weighs as much as you think. Sounds as if your numbers are the weight of the trailer and the maximum cargo in it. You should visit a set of scales to see where you really stand.
I have a 3/4 ton diesel crew cab, and I limited myself to 11K dry weight and 2K dry kingpin lbs. in a trailer.
All of the Big Country and Big Horn models, except maybe the smallest one, will exceed the capabilities of single rear wheels due to their limited pin weight. Such trailers need a 1 ton dual rear wheel.
So you tow your RV dry only?
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
Bamaman11
Winged_One
Glenalt wrote:
Thanks Lyle. The bad thing is trying to find out if it's legal in my state, SC. Then when you move into a neighboring state if it's legal there, especially with the controversy surrounding it's designation. I still would like to know where I can get one. thanks. Glen
I got mine off Craigslist.
Searchtempest works well for searching multiple craigslists all at once.
You can also buy new from: Manufacturer
I have the 58dw.
2013 F350 6.7 DRW SC Lariat
2011 Brookstone 354TS
Swivelwheel 58DW
1993 GL1500SE
Yamaha 3000ISEB
Glenalt
laknox
Glenalt wrote:
Winged One wrote:
fj12ryder wrote:
Only people who have driven both are qualified to say which drives better.
I see you have a single wheel trailer with your bagger on back. I would like to do the same. Where can i find a unit like that? It sure looks nice. Glen
Glen, that's a 2-wheel swivel-wheel. You can see the off wheel just behind the LR tire of the FW. Make sure that they are legal in your state, and where you might be traveling. They're OK in some states, but others define them as a "trailer", so it's a double-tow, and aren't legal. And to confuse matters, in some states they are =not= defined as a trailer, so don't count as a double, but the LEOs don't know this and will cite you for a double.
Lyle
2017 KZ Durango 1500 D277RLT
1936 John Deere Model A
Glenalt
SkiSmuggs
rhagfo wrote:
AlabamaTraveler wrote:
I had an f250 with a 28ft 5er. When I moved up to my 33ft 5er with 2 slides, I immediately got an f350 diesel dually. I love my truck!!!!!
Intresting I pull a 33' 5er with a Ram 2500 and it handles the load fine. The 5er has a 12,360# GVWR and tows at about 11,000#.
2015 F-150 HD Payload would have no problem with that, but that is another thread altogether!
For those looking askance at my sig, my rig has a GVWR of 10K, but tows at 9500 lbs with a TV rated at 11K.
2015 F350 XLT PSD 6.7 Crew Cab, Andersen Ultimate hitch
2012 Cougar High Country 299RKS 5th wheel, Mor/Ryde pinbox, 300w of solar
lakeside013104
Dog Folks wrote:
Don't need a "dully." Did you mean Dually?
Don't need brakes either, but both sure come in handy.
Thank you so much Dog Folks, after reading your post, most of my coffee was warming my lap............:B
Lakeside
rhagfo
AlabamaTraveler
Lawrence, Dianne "Roll Tide"
blt2ski
Moderator
Moderator
Taught both daughters to drive a dually crew cab. Took there driving test in a reg cab C2500! What is the problem with women driving big pickumups! I even see some driving class 8 rigs. Pickumups are puny compared to those rigs! I also know a few that are captains on 100ton boats too!
Oh, you only need about 10hp to move 100k lbs on a level at less than 5 mph! Just need the correct gearing to make the torque large enough to move the subject!
Marty
92 Navistar dump truck, 7.3L 7 sp, 4.33 gears with a Detroit no spin
2014 Chevy 1500 Dual cab 4x4
92 Red-e-haul 12K equipment trailer
wandering1
lee worsdell wrote:
are 1ton axelses and brakes not the same as 3/4 ton. sure look like it when we had it all apart on my truck. same rotors, rear end no difference other than a extra tire
HR
JIMNLIN
grahampconrad wrote:
I had a post some time ago about, Pulling a 38 ft . This post had some mistakes of witch i am sorry for. And all of you told me that. Try it again Sorry. My rig is 15000lbs and i pull it with a 16k Rease . with that i think i should okay? Sorry again i will proof better next time.
Thanks for the clarification. Sure made for some silly/entertaining comments by our weight police force. :B
