Question on hitch and pin box height.
Toolguy5
Went from a 2006 2500 HD Silverado to a 3500 HD Sierra Denali. Buying a new B&W companion slider. The Slider has a height adjustment of 17 to 19 inches. To get the 6 inches of clearance from 5er overhang to truck bed rails I need the 19inches of height on hitch.
That puts the 5er about 8 inches off level from front to back. There are 2 holes left where the pin box can be raised. If I take the pin box all the way up to narrow the distance from front of 5er to rear. Will that also reduce the 6 inch clearance I need for bed rails.
Just having a difficult time trying to envision the outcome.
Dan & Patty
Miss Pickles the Pomeranian Princess Rainbow Bridge 8/8/2023
2020 GMC 3500 Sierra Denali 6.6 Duramax / Allison tranny
2021 Jayco Eagle 319MLOK
BWRVK 3710 companion
Maddy the Pampered Pom @ Rainbow Bridge 12-3-2013
18 REPLIES 18
partsman01
SanMarMor wrote:
If you raise the pin box, isn't that going to lower the body of the trailer back down closer to the rails?
Yes it will, to increase height one needs to raise hitch and lower pin box, that is the basic adjustment as I understand it, in fact forget what my old 1996 GMC 3/4 ton height was, as now with it written off I now have a 2003 GMC 3/4 ton, and it has a factory lift, so will have to see if I can adjust mine for the right clearance.
SanMarMor
2007.5 Chevy 3500HD Crew DMax Dually 4x4 w/ Curt Q5 20K Hitch
2011 Sabre 31RETS-6 w/ TrailAir Pin
44 nights in 2013, 37 nights in 2014, 27 nights in 2015, 29 nights in 2016
34 nights in 2017, 27 in 2018
http://camping.morrises.com/
Toolguy5
CumminsDriver wrote:
I have the B&W Companion Hitch in the middle position, with the pin box raised up 2" from the lowest position. The trailer is just slightly nose high with 6" of clearance between bed rails and trailer.
Rich
Doing some measuring I believe that is where I will end up after installing the 2 inch lift kit, (axle alignment).
Dan & Patty
Rich1961
Rich
2016 Chevrolet/Duramax 3500HD Dually Crew Cab B&W RVK 3700 5th Wheel Hitch
2014 Arctic Fox 29-5T
Toolguy5
I sold the hitch when I sold my 2006 2500 HD. I have a new hitch on order. The dealer is unable to install until mid June. We are looking at the LCI correct track system to raise 2 inches. Then once the hitch is installed we can play with the Pin box. So between the pin box and hitch height adjustment I feel a lot better on being able to get close.
My pin weight is right around 2100 lbs.
Thanks for all the help.
Dan & Patty
Lantley
rhagfo wrote:
hbillsmith wrote:
Read somewhere that adding the LCI Correct Track system raises 2 inches.
X2 that is correct, I hope to find the time in the next month to install mine.
I just had Correct track system installed. Raise the rear 2".
Allowed me to Increase bedrail clearance from a marginal 4" to a comfortable 7".
19'Duramax w/hips,12'Open Range,Titan Disc Brake
BD3,RV safepower,22" Blackstone
Ox Bedsaver,RV760 w/BC20,Glow Steps, Enduraplas25,Pedego
BakFlip,RVLock,5500 Onan LP,Prog.50A surge,Hughes autoformer
Porta Bote 8.0 Nissan,Sailun S637
Correct Trax,Splendide
Shepherd
Whats your pin weight? With my unit I have 5" clearance and have had no contact with bed rails, have cone close on my driveway,
2018 Ram 3500 CC aisin/4.10
2014 Rushmore Monticello
rhagfo
ACZL
Off subject, but looking at your pics, you may want to consider replacing the trailer susp w/ a Equa-Flex or at the very least install wet bolts.
2017 F350 DRW XLT, CC, 4x4, 6.7
2018 Big Country 3560 SS
"The best part of RVing and Snowmobiling is spending time with family and friends"
"Catin' in the Winter"
hbillsmith
Wildcat2016-295rsx GMC2015-2500HD-DblCab D'max/Allisn+4x4 6.6'Bed
Maxxis235/80/16E;Andersen Ultimate2+4"offset;Airlft1 WirelessComp;GroundCtrl3;MorRyde RubbPinBox+CRE3000;3-Slidecovrs;Champion3100w/DIY ExtndRun;10'Portabote+5hp;Furrion48cam
Visited States
RCMAN46
You and several thousand others is a victim of the bed height war the big three has had in the last 10 years.
For some reason they make the 3500 series trucks for the kids that want a macho high lifted truck and not a truck that can tow a trailer unless it is one of the newer ones that exceeds 13 ft in height.
Me_Again
You need to hook it up with the pin weight on the truck to know what you are up against. The new trucks with soft springs for a nice ride settle more than older trucks.
Chris
Me_Again
If those are 15" ST tires, you can gain some height and reliability with LT235/85R16E tires. Check that you have at least 33" center to center on your axles and some extra room above the current tires.
Chris
laknox
Thanks for posting the pics. Nothing to do but add a sub-frame of the height you need to get level. 2-3" nose-high isn't too bad, but 8" is really too much. Doing this will also allow you to get =more= than the 6" minimum clearance you're seeking, if you so desire.
Lyle
2017 KZ Durango 1500 D277RLT
1936 John Deere Model A
