Sliding Hitch
Rwake901
Who has a 6 1/2 ft bed and doesn’t use a sliding hitch? I’ve had two RV dealers and the company that makes the 5th wheel we are interested in tell me I don’t need a sliding hitch with a standard 6 1/2 ft bed. But when I go to Curt’s website (the maker of the hitch) they tell me I do need a sliding hitch. (Plus I emailed them) Who do I believe? I’ve read some other posts where people say they have one but never use it. Thanks for the help.
31 REPLIES 31
cummins2014
schlep1967 wrote:
No you don't "need" a slider. Just like you don't "need" a seatbelt when riding in a vehicle. Until you do.
I went through this same questioning when I moved to a 5th wheel. My issue was, I can buy an auto-slider and never have to worry again or I can by a manual slider and wonder every time if I should make the effort to get out and slide the hitch.
I don't regret the auto slider one bit.
Now, everyone is different. If you are skilled at backing a 5th wheel you will probably never have to jack it much past 45 degrees to get it where you want it. If you are not skilled..... you will be approaching 90 degrees often. This can be a very good determining factor as to what kind of hitch you want.
The amount of degrees you have to back into a spot, can't be determined by your skill , if there is room you can back in at 45 degrees , anything will eventually given the room will get to where you want at 20 degrees. Your statement does not make sense.
I have a manual slider , I don't use. I also have a Andersen hitch, that is no issue in backing. Yes sir it is a skill to back a fifth wheel , and if you need a auto slider then so be it. Many don't.
Its a situational awareness event, and if you don't have awareness of what you are doing then sliders are not of much use.
topjimmy
No you do not need a slider in my experience with newer 5er's I have a 6 1/2 ft Crew Cab short bed GMC with a Reese 18K NON slider and never had any problems in this last year of owning it and yes I have made many tight turns backing up with room to spare to the back window and I knew I would not have a problem as My buddy has had a Ford Short bed for years with no slider and never had any problems the key here is NEWER 5er's with a curved cap like was said before
2015 Montana 3735MK Legacy,2007 3500HD GMC Dually LBZ Duramax/Allison ,Pacbrake,Firestone Airbags Bullydog Tuner
schlep1967
2021 Chevy Silverado LTZ 3500 Diesel
2022 Montana Legacy 3931FB
Pull-Rite Super Glide 4500
laknox
I have a B&W Companion, non-slider, in my 6.5' D'max. I =have= taken out my back window with my old, very square-front Komfort, while backing up; just got impatient and was turning one way while looking the other. I could =not= hit my cab, turning R or L at full lock, when going forward. ALL will hit when backing up; a slider just gives you more time before you =will= hit. With my new KZ, I have even more room, since it has cut-away front corners. So, with care and patience, you shouldn't need a slider. There are any number of posts from people who have sliders, never used them, then, when they decided they =did= need to use it, the thing was rusted so bad that they couldn't move it.
Lyle
2017 KZ Durango 1500 D277RLT
1936 John Deere Model A
JIMNLIN
Curts website doesn't know what your trailers front corner profile looks like and others that don't know will say get a sliding hitch.
Pay close attention to Dayle1 reply in his first paragraph where he says:
You don't need a slider if you can remember to pay attention. But as already stated some of that depends on the variables. Bed length is not an issue. Cab-to-axle (CA) distance is , GM is the longest, Ford just a little less and Ram is the shortest. Then fiver cap design is the other big factor.***
Many GM owners with the newer rounded/notched front corner profile don't need a sliding hitch at any angle mainly because of that longer C/A (back of the trucks cab to the trucks rear axle). Also installing the hitch with the pin zero over the rear axle helps also. The last 3 trucks I've owned were crew cab short beds and always have my pins zero over the axle.
The larger RV dealers who carry several hitch brands and installation can help you there.
Others like myself have a Dodge with a 6' 4" bed and pull a older '97 30' 5th wheel trailer with flat square front corners. Sure I need a sliding hitch but its seldom used.
I have found that backing with the hitch slid back all the way places the pin 10"-11" behind the trucks rear axle.....this causes the trailer to react quicker with less steering input while backing in a really tight/twisty situation.
spud1957
They are more expensive but not needing to stop, drop landing gear, slide, put gear back up gets to be a pain.
No, you do not drop the landing gear. As stated and per the hitch user guide, you manually lock the brakes on the trailer.
If the nose of the trailer is close in a parking lot, all it takes is one side of the RV to be on unlevel ground at the campground backing and you may tap your cab or worse your window.
2018 F350 6.7 4x4 CCSB
2022 GD Reflection 337 RLS
2012Coleman
Bionic Man wrote:
Dead horse here but it depends on the trailer.
On our first RV I never used it. When we changed to our current trailer with our old short bed truck I needed the slide every time I took it home.
And I agree with those that say if you need a sliding hitch to spend the extra $ and get an auto slider. They are more expensive but not needing to stop, drop landing gear, slide, put gear back up gets to be a pain.
Stop and drop the landing gear to slide the hitch? Why on earth would you do that?
I have a Ram short box with a B&W companion slider. To slide, I get out and unlock the hitch with the handle, apply full brakes to the fiver using the controller to lock them up, and pull ahead slowly. The hitch slides back and locks. I only drop the landing gear when I'm ready to unhook. Backing up with it slid back is actually easier. I can stick it in the same spot in my driveway every time.
I have a modern fifth wheel with the rounded corners and need it to back into my driveway and some camp sites.
So, mindful of the comments of you don't need one, I didn't slide it back the very first time I brought it home - I can tell you that the turning radius on my 2017 truck was more than enough to enable contact with the cab as evidenced by the sound of breaking glass.
Maybe the comments about the Ram having the hitch placement the closest of the three are correct, but decide for yourself.
Also, when considering an auto slider, make sure you can back into it at an angle. The ones I researched required the ability to back straight in.
So if I was only going to pull through spots or had a huge property, maybe I'd never need to slide it. I don't need to slide it when backing into my space at storage.
That's my experience - good luck with your decision.
2018 RAM 3500 Big Horn CTD
ACZL
That's what "D" is for in transmission..
2017 F350 DRW XLT, CC, 4x4, 6.7
2018 Big Country 3560 SS
"The best part of RVing and Snowmobiling is spending time with family and friends"
"Catin' in the Winter"
mtofell1
camp-n-family wrote:
The only way to really know if you need a slider without a hitch installed is to back the truck under the fiver at a 90 degree angle leaving a few inches between the cab and cap. Will the pin be centred in the bed and over the axle? If so, you don’t need a slider.
Lots of people who have done this hit their cab due to the 5th wheels being on uneven ground and tilting the cap into the cab. The proposed test is presumably done on flat ground. Problem is the world isn't flat 🙂
twodownzero
get an auto slider. Don't ask how I know.
GHop
I'm not going to tell you what to buy. I have a RAM Mega cab with a short bed and had a slider for 5 years now. Never had to engage the slider and I have gotten into some tight spots. I will say, I believe it depends on the design of the front cap. The corners of the caps on both of our fifth wheels were a cutback design on the corners (Not sure if that is the correct). Get the slider, everything RV cost so go with it. Over time, you are going to waste more money on things you wanted for the RV and never use them.
G.H.
Bionic_Man
2012 RAM 3500 Laramie Longhorn DRW CC 4x4 Max Tow, Cummins HO, 60 gallon RDS aux fuel tank, Reese 18k Elite hitch
2003 Dodge Ram 3500 QC SB 4x4 Cummins HO NV5600 with Smarty JR, Jacobs EB (sold)
2002 Gulf Stream Sea Hawk 29FRB with Honda EV6010
Dayle1
Regardless of setup, you will not get into trouble making a 90 degree forward turn, the steerable wheels of the truck can only turn about 36-37 degrees max. So, a 90 degree turn at full steering cut will only result in a truck to trailer angle of around 45 degrees. You cannot make a 180 degree turn at maximum steering cut, but you can make a 180 degree turn at less than max. steering cut.
Where you will get into trouble is when jockeying back and forth to get into a camp site. That is if you try and get by with the least maneuvering. In 30+ yrs, I've never found a spot I couldn't get into if I was willing to take a little extra time maneuvering. Four SB trucks and 7 fifth wheels and never made contact between truck and fiver.
Larry Day
Texas Baptist Men-Retiree Builders since '01
'13 Silverado 3500HD LT 2wd CCSB SRW, custom RKI bed
'19 Starcraft Telluride 292RLS
Rig Photos
Bob_Sue
Get a slider. Matter of fact get an auto slide, it always works when it should. That way you cant forget to use it. Happy I got mine.
Bob&Sue
2021 Cedar Creek 34IK
2011 Ford F-250
6.7 litre PSD
Pullrite Superglide
Jimbee
It depends on the model 5th wheel you're looking at. If it has a Revolution/sidewinder style pin box you won't need a slider. If it's a conventional 5th wheel some models have uniquely shaped noses sculpted for extra clearance around turns. It would be nice to have the slider in case you're in an awkward situation backing in. Better to have it even though you made rarely need it!
