โOct-28-2014 10:21 AM
โOct-30-2014 08:25 PM
โOct-30-2014 08:12 PM
john&bet wrote:Cummins12V98 wrote:buckdaddy wrote:
I'm thinking of adding air bags to the rear suspension on my 06' Ram 2500 since I started pulling an 8300lb 5th wheel. Any recommendations on brands & gotchas as well as psi settings. Did it make a difference in handling, ride quality, or stance of vehicle? Right now its a little squat when pulling.
At that weight you should not need anything!
X-3. I pull a 12,000 5th with a '04 2500 and have only a 2" drop in the rear. No squat. Just nice and level.
โOct-30-2014 05:30 PM
buckdaddy wrote:g4sbrg wrote:
did the system take the bounce out on those road level changes. that's about the only thing in my new to me 5ver setup seems to need improvement on, pulls straight, handles well just that one bounce at hwy speed could be improved, or do they mostly do that anyway???
This is the main issue I would like to see improvement with also: bounce. Thanks for your input guys; the jury is in, now all i have to do is decide Ride-rite or Pacbrake.
โOct-30-2014 10:27 AM
โOct-30-2014 08:47 AM
โOct-30-2014 02:11 AM
N-Trouble wrote:
The advantage of separate lines is air volume will stay constant in each bag. When using a T or compressor feed from a single line air can travel back and forth between each bag as load shifts.
The downside of course its a bit more work to fill.
โOct-29-2014 04:24 PM
โOct-29-2014 04:02 PM
crcr wrote:fj12ryder wrote:
I'm very happy with the Firestone air bags I have on my Dodge dually. Separate air valves and fill with an air bubble.
What is an "air bubble"? My truck's air bags also has separate air valves, so I find it hard to get the exact same pressure in each side.
โOct-29-2014 03:16 PM
โOct-29-2014 01:56 PM
โOct-29-2014 01:26 PM
avvidclif1 wrote:
Try new shocks for the bounce.....
โOct-29-2014 07:33 AM
โOct-29-2014 07:10 AM
โOct-29-2014 05:43 AM
