Build quality gas vs DP
Snowman9000
I looked at a 2001 Foretravel DP. It was the U270, their lower line at the time. Loved it. Is there any gasser that has high end build quality like that? I'm assuming not.
Currently RV-less but not done yet.
50 REPLIES 50
-Gramps-
Chances are you will not find an HR or Monaco Rear Gas for sale anywhere but there are some Winnies out there. The Adventurer LTD rear gas is a fine coach, almost bought one myself. Based our our coach I would say yes there are some gas models that are well built but I can't testify to that personally for the last few model years, have not looked at too many of them.
___________________________________________
Fulltimer in 08 Holiday Rambler Vacationer 38PLT Workhorse UFO GAS Pusher Chassis
06 Saturn Vue toad, SMI Breaking sys,Blue Ox tow bar.
My Random Views Blog
Smitty77
wolfe10 wrote:
Snowman9000,
If you are asking if there gasoline coaches with build quality comparable to a 2001 Foretravel U270, the answer is NO. But, it likely cost at least twice what the most expensive gas coach did when it was new. Not reasonable to expect quality to be the same.
BTW, no difference in build quality between the different Foretravel models-- just drivetrain and equipment differences. Same construction.
BTW, here are specs on the 2001 Foretravel U270:
http://www.beamalarm.com/foretravel-links/models/2001-u270-
foretravel-specifications.pdf
X's 2.
For gas Class A's, I felt that three of them were of above average construction build:
-Mountain Aire (Already mentioned)
-Tripple E
-Rexhall
National also had the Dolphin line, on the Workhorse chassis, that were well built with good materials and components, towards the last few years of their operation.
And as also mentioned, all subject to opinion:)!
We looked real hard at the UFO 8.1 rear engine Class A's, as a hold over coach until we retired. Ended up keeping our Bounder, but only because we decided to pull our retirement date forward a few years. I liked the Monaco Holiday Rambler and Rexhall UFO based Class A's too.
Happy hunting,
Smitty
tropical36
Probably not vs the Foretravel, but with the title of your subject matter, a high end gas unit can very well be better quality than a low end DP
Snowman9000
Thanks for the info folks. That Foretravel spoiled me. But it's good to know that in some brands the high end gassers would be pretty well built too.
nevadanick
I just traded a 2014 Tiffin Red for a 2016 Phaeton. The Red is entry level and it shows. If the gassers from Tiffin are on par with the Red then they have a long way to go as even this Phaeton isnt up there with the big $$ rigs.
tatest
From plant visits, I am fairly sure that Winnebago and Newmar build their gas motorhomes at the same level of construction quality, using the same techniques, as their base-priced diesel pusher lines. Top level gassers will also be trimmed similarly, and pretty close in price, to the least expensive diesel pushers.
At Newmar, this overlap once went pretty high up the line, with the Mountainaire built as both gas and diesel. At a lower price level, Kountry Star was once built as gasser and entry-level diesel for a while.
I would expect the same from Tiffin. Some of the Monaco Corp brands, Monaco and Holiday Rambler for example, had this overlap between low-end pusher and upper-end gasser, and
But any gasser built like a Foretravel U270, I don't think so, as that was a semi-unibody motorcoach, not a RV box built on a bare rail chassis. Old Bluebirds might be comparable but still different, but there were no gassers after the late 1970s. Same for Newell, moved from front gas to front diesel to rear diesel as the market changed.
Tom Test
Itasca Spirit 29B
Dale_Traveling
Looking at new rigs, a mid priced DP and high end gas coach are getting pretty close. Step back a few years and the separation begins to grow. Move out to maybe 10 years and the build quality has less of an concern over owner maintenance. Park a high end DP in a storage lot and never touch it for years and it's going to rot just as fast as a low cost gas coach under similar circumstances.
Foretravel is a bit of a different animal than you basic assembly line mass produced rig. Difficult to compare.
2006 Hurricane 31D built on a 2006 Ford F53
DSDP_Don
"Snowman9000.....I would take a look at the top of the line gassers in Fleetwood, Tiffin, Newmar and Winnebago. I think one of those might fit your idea of a nicely built unit with quality components.
Don & Mary
2019 Newmar Dutch Star 4018 - All Electric
2019 Ford Raptor Crew Cab
nevadanick
My belief is that with quality comes weight and the gas chassis mh's are not yet up to that sort of weight carrying.
dezolen
Well Tiffin Open Road has almost all the same components as the Tiffin RED DP.
Same cabinets same roof, same sidewalls, same appliances same outside compartment doors as the Phaeton. It's engine cannot be heard other than uphill climbs
Just saying
Mondooker
Hi Snowman9000,
I should stay out of this because I'm a new to all this but here's my 2 cents worth.
I'll not go into a long conversation about my specific situation but I was looking at nothing but diesel pusher's. One fine day someone here on the forum said "hey, why not look at a gasser"! So I did and what I found surprised me very much.
The top end Newmar Canyon Star, Tiffin Allegro and Winnebago Adventurer are some fine gassers. And it wouldn't hurt you a bit to take a look and see if they work for you.
Foretravel is close to the top of the diesel pusher food chain and I think most would agree can't really be compared to a gasser!
Busskipper
IMHO your assumption is CORRECT.
JMHO,
Busskipper
Maryland/Colorado
Travel Supreme 42DS04
GX470-FMCA - Travel less now - But still love to be on the Road
States traveled in this Coach
wolfe10
Snowman9000,
http://www.beamalarm.com/foretravel-links/models/2001-u270-foretravel-specifications.pdf
Brett Wolfe
Ex: 2003 Alpine 38'FDDS
Ex: 1997 Safari 35'
Ex: 1993 Foretravel U240
rgatijnet1
Snowman9000 wrote:
I don't see the reason for those replies. I am NOT asking about the usual gas vs DP question. I'm asking if there are gassers that have build quality like good DP rigs. I probably worded the title wrong and so some people can't wait to post "not this again".
The problem is most DP's do not have the quality of a decent DP like a Prevost chassis type coach. There are so many levels of quality that it is a difficult question to answer. I have had both DP's and gassers and I find that all of them have their good points and all have their bad points. Some gassrs had better cabinets than some of the DP's I had. The thing is I never had a cabinet fail so to me that is irrelevant. Then again, I never had an engine fail, so both diesel and gas got me where I wanted to go. I also have several thousand miles in a Liberty Prevost coach and know that most DP and gas coaches are not even close to the same quality level of a really high end coach made to last for hundreds of thousands of miles and decades of use.
You need only to decide what is important to you, and go for it. There is not right or wrong answer as the only choice that ever matters is yours.
Cloud_Dancer
In the offerings for 2016, and in the $600K to $750K range, the DP's that I have in mind are obviously of higher quality than any gasser. IMO most of us here simply can't afford the quality that we want. Therefore, we have to compromise.
ME? I had to compromise a LOT!
The sad thing is that it takes great deal of exposure/experience with motorhomes, PLUS you need to be a "gearhead", plus you need some construction/fabrication/design experience, plus you need the freedom to go checkout many models,....etc, etc,....in order to have a chance of selecting "the best in the bunch". Just asking the right questions is an art in itself.
If it was easy, there wouldn't be so many cases of buyers' remorse.
Willie & Betty Sue
Miko & Sparky
2003 41 ft Dutch Star Diesel Pusher/Spartan
Floorplan 4010
Blazer toad & Ranger bassboat
