Jul-31-2016 06:20 PM
Aug-03-2016 07:45 PM
Ivylog wrote:Crazy Ray wrote:
GET V10
There is a lot more to deciding to get a DP (OR NOT) than just the engine. Granted if it only has the little Cummins 5.9 engine (older ones had dowel pin problems) and as a previous thread said: "the insides look like a travel trailer" there is not enough difference to go diesel.
In the past a V10 could handle a max of 36' of MH (yes I know there were a few longer). Today you are seeing it in 38' units, but longer/heavier than that you need a 7.2L DIESEL engine or BIGGER (Yes, I know there are some with Cummins 6.7... a good little PU engine).
Normally in a 38' or bigger DP you are getting more than just a quieter ride (without adding Dynamat), air brakes, and air ride suspension... you should be getting a much better built rig with solid wood cabinets, tile, Corian, four slides............ and good handling without adding track bars, steering stabilizers, upgraded shocks, bigger sway bars......... and you get a 10K hitch.
Aug-02-2016 07:35 AM
Aug-02-2016 04:33 AM
Mile High wrote:
Wonder how many of those diesel failures were chipped.
Aug-02-2016 01:10 AM
rgatijnet1 wrote:Yep, and many of those they sell end up converted into very nice class A motorhomes, while many more likely go to companies in poorer countries, like Mexico and countries in central and south America, where they do another million miles before they go to the junkyard.SoCalDesertRider wrote:
There are, however, a huge number of rear engine diesel commercial passenger/tour busses, and have been for many decades...
Yep there are and every one of them gets regular maintenance at a professional garage. I would guess that all of them are turned over as soon as they get to a certain mileage or when the repairs start to add up to where they are no longer financially efficient.
Aug-01-2016 08:26 PM
Ro646a wrote:
I'm considering purchasing a used diesel pusher. I miss the quiet ride with the engine in the rear.
I have had three class A motor homes with the 310 HP V10 and they all performed flawlessly. I have never read about anyone having any problems with the V10 other than the spark plug issues on the early models and some trouble with exhaust manifold bolts. I have never had those problems with mine.
One thing that I have noticed concerns me. In looking at ads for used diesel pushers over the past several months I have noticed several with a lot less than 100,000 miles advertising the fact that they have had the engine rebuilt. I just saw an ad for one today with 55,000 miles and a rebuilt engine.I thought these engines were
supposed to last a long time. I have never seen an ad for a motorhome with a rebuilt V10.
Considering the costs associated with owning a diesel this is kind of scary. The used models I have looked at have all been 2003 or newer.
Aug-01-2016 07:06 PM
Aug-01-2016 06:47 PM
Aug-01-2016 05:04 PM
Aug-01-2016 04:37 PM
Aug-01-2016 04:17 PM
Dale.Traveling wrote:What is the cost of a new V10 crate from Ford? I heard around 5-8K? That really isn't too bad if a new engine is need considering the cost of a new RV. If you maintain the coach like I do, slapping in a new engine at 200K miles is not that bad.
I think it comes down to economics. Cost of the rebuild verses the value of the coach. I currently own a 10 year old gas rig with a V10. If the engine blew tomorrow it would probably be a hard sell to front the cost of a rebuild considering how much the coach is worth. Change the coach to a 10 year old diesel and I might be more inclined to take on the cost.
Then again as a shade tree mechanic would be an interesting project to do a V10 overhaul in the driveway.
Aug-01-2016 01:47 PM
Aug-01-2016 01:38 PM
Aug-01-2016 01:36 PM
Aug-01-2016 01:15 PM
