โJul-28-2018 06:33 PM
โJul-30-2018 07:09 AM
โJul-30-2018 01:34 AM
Stim wrote:X2
For all, you need to use one of the white hoses (designed for potable water), NOT just a regular hose!
Regular hose might have chemicals you don't want in your water.
I always drained and rolled up white hose and connect it to itself to keep it clean and run plenty of water through it before using it again.
โJul-29-2018 09:43 PM
โJul-29-2018 05:33 PM
โJul-29-2018 02:51 PM
โJul-29-2018 01:42 PM
โJul-29-2018 12:36 PM
โJul-29-2018 11:03 AM
โJul-29-2018 07:45 AM
vjswhippet wrote:That's a mistake I've made before. It doesn't take much of that stinky water to smell up the tank.
I should have run the hose before filling my FW tank.
โJul-29-2018 07:35 AM
โJul-28-2018 10:33 PM
โJul-28-2018 08:42 PM
MobileBasset wrote:
The chlorine in city water is only effective for a short while. If the water sits for very long it will grow organisms. In very rainy times when much less water gets used because no one is watering their lawns, cities can have problems with their water tanks going bad from low usage. The RV systems need to either keep treated water flowing through at a good rate (refilling and using up and refilling) or be emptied and sanitized periodically. Sanitize by emptying and refilling with 1/4 cup bleach per 10 gallons of water, open all the faucets until you smell the bleach, let it sit for a few hours or more, then empty and rinse until the smell is gone. I close off the hot water heater from this process but make sure I open it and get it thoroughly rinsed with fresh treated city water.
โJul-28-2018 07:56 PM
โJul-28-2018 07:12 PM
