Jun-19-2013 04:05 PM
Jun-20-2013 01:51 PM
Jun-20-2013 01:50 PM
Jun-20-2013 01:34 PM
Jun-20-2013 01:24 PM
Jun-20-2013 01:03 PM
Jun-20-2013 11:55 AM
Jun-20-2013 11:31 AM
Jun-20-2013 11:22 AM
Jun-20-2013 10:59 AM
Jun-20-2013 08:42 AM
bsinmich wrote:msmith1199 wrote:bsinmich wrote:
When a CG in Cincinatti told me I had to put pads under my jacks I got a refund and left. I physically can not get down on the ground to position it properly and still get back up. DW has also had 3 knee replacements and should not get down on her knees. (she wore 1 out after 10 years. she really only has 2 legs) When I go to my cousin's place on his alphalt drive he puts the boards down.
You should have explained that to the campground owner and I'm sure they would have come to help you.
He was the one that told me I had to use them and was right there when I said I could not get back up if I got down that far.
2021 Nexus Viper 27V. Class B+
2019 Ford Ranger 4x4
Jun-20-2013 05:21 AM
Jun-20-2013 04:13 AM
Jun-19-2013 10:49 PM
Jun-19-2013 08:45 PM
J-Rooster wrote:
S-n-L, I use 2" X 10" X 8' Douglas Fir wood blocks! I buy the wood at Lowes, and I have them cut them into 2' sections. Lowes does 3 cuts for free, which makes 4-2' boards and no cutting or hauling a long board home! I've used everything and this works the best for me. And they won't wear out in my lifetime. I really like how they work in soft ground and in the heat (where my jack would damage the asphalt) they disperse the weight of my coach and transfer it evenly thru the 2" X 10" board. Good Luck in whatever you choose.
Jun-19-2013 08:44 PM
hammer21661 wrote:
I usually use a 6x8 about 14 to 18" long if I am worried about sinking I place it on a pair of 2x8s or 3x 8s about 14 to 18" inches long. I lay them down next to one another and cross with the 6x8. They will not sink unless you are camping in a marsh. If height isn't an issue I would probably use an 18" 3x10 under each pad two with a cross piece the same dimention if I was worried with your rig. The out rigger pads are pretty expensive aren't they? I also Use a short boat hook about 3 or 4 foot,it works wonders for reaching things.
