โJul-27-2017 08:46 AM
โAug-06-2017 04:16 AM
Beachme wrote:
I bet the frame was already bent when the Motorhome was made how long do you have it and And was it like this before or is this the first time you were looking under it
โAug-05-2017 04:31 PM
โAug-03-2017 07:53 AM
โAug-02-2017 11:24 AM
willald wrote:
Update: stopped by and talked to Cummins Atlantic today, a big Cummins truck shop in Charlotte. They don't do that kind of work, but in a case of real good timing, they told me of a guy that used to work for them, that they highly recommend, that now owns his own shop doing exactly that kind of work - metal fabrication, welding, frame repairs, etc. He was sitting right there, we talked about it, I showed him the pictures, etc. He talked about several different ways he could fix it, pretty much consistent with the various ways discussed on here. Everything from straightening out the c channels and reinforcing bottom of C channels with fishplates on top and bottom, to replacing entire frame extension and fabricating a new receiver hitch that would be much stronger.
Anyway, I goog to check him and his company out, DD Diesel. Want to have a look at his shop, make sure it's somewhere I'd feel safe leaving the RV while he works on it. One other place I'm going to check with is Holbert Trailers. They are a much bigger company that could definitely do the work.
โAug-01-2017 05:47 PM
StuckinTracy wrote:StuckinTracy wrote:willald wrote:
I was thinking of one way I may have contributed to this: I use a 4" drop receiver, to get the tow bar close to level with the toad. Every time we come back from any trips, when I back the Motorhome up the driveway, due to the incline of the driveway and that drop receiver, the bottom of the receiver does scrape a little back there. The scraping seems very minor, but scraping when going in reverse would indeed push down on the receiver, or to say it more correctly: It would put torque on the receiver consistent with direction the frame has twisted. Even though its been very light scrapes, maybe that's been enough over time to cause this. That is only thing I can think of that I've done, that could have caused or contributed to this.
Maybe you missed my previous question?
Just curious, you say you use a 4" drop receiver that slightly scrapes when you back into the driveway. Are you referring to the ball mount that slides into the motorhome hitch? If so can't you simply remove it when you unhitch the toad, before you back in? If you mean the entire motorhome hitch is lowered by 4', then please ignore and forgive my ignorance.
โAug-01-2017 04:48 PM
โAug-01-2017 12:38 PM
โAug-01-2017 10:16 AM
tropical36 wrote:
Whatever the case here, I'd get it fixed and double reinforced.
Also have my toad hookup reviewed for any flaws, whatsoever.
โAug-01-2017 08:45 AM
โJul-31-2017 06:41 PM
โJul-31-2017 02:29 PM
โJul-31-2017 01:03 PM
willald wrote:RLS7201 wrote:
Another possibility is, steep tow bar angle and a panic stop, with no auxiliary toad braking.
Only way that could be the case, is if the towed vehicle was higher than the receiver, and tow bar was angled up, toward the toad. Very rare, its almost always the other way around.
With both of our toads, it was the other way (toad was lower), to the point I've always used a drop bar to level it out some.
Now, I can think of a handful of sudden stops I've had to make, but, there has always been a supplemental braking system in use (Readybrake).
Will
โJul-31-2017 09:11 AM
โJul-28-2017 03:59 PM
โJul-28-2017 03:25 PM
