Nov-04-2015 03:33 AM
Nov-08-2015 05:45 PM
rjxj wrote:Now that's nice!
It was a positive experience with someone who isn't a jerk and we have made the rv'ing world a better place for all 😉
Nov-08-2015 05:35 PM
jwmII wrote:rjxj wrote:jwmII wrote:rjxj wrote:Executive wrote:rjxj wrote:
/snip/ but I'm guessing /snip/
THIS ^^^ says it all....:S
Unless and/or until you do your research, don't guess.
That said, we don't boondock very much but we've enjoyed up to a week without external power. We run the genset in the morning while making breakfast and in the evening while watching TV. We've had ours for over a year now and wouldn't go back to a Notsocold ever again.
For those thinking of changing over, HERE are pictures of my installation. I did it myself, in a campground. Took me two days and several trips to the local Home Depot, but it was well worth it....Dennis
By the way, how much calculating did you do to figure out that you could run a residential on shore power or annoy people by running it for a week while on generator. What did you have to figure out or guesstimate? Oh you had to use a tape measure. Got it. 🙂
Why do so many folks think that running a generator is annoying to people? Mine doesn't bother me at all.
Most puzzling is when they park in the generator area and run it absolutely every minute of generator hours when for $8.00 a day more they could have full hook ups. Can you really run a noisy gas generator that's built into a class A for 12 hours for less than $8.00 a day. :R it wasn't heating or ac weather either. I was guessing dry batteries, junk converter or maybe a hamster on a cpap machine thingy.
So! Who cares?? Their business if they want to run their generator all day. It doesn't matter if they can run their built in generator for less than $8.00 a day. Their business. Mind yours. Stay home. Good grief!!
Nov-08-2015 03:42 PM
Nov-05-2015 02:52 PM
Nov-05-2015 05:45 AM
Nov-05-2015 05:37 AM
CA Traveler wrote:
On another board a poster measured his Samsung RF 197 power with a Kill A Watt and found that it uses 1820 watts daily. That translates to about 150AH from the battery which can be significant for dry camping and is a huge drain on the common 4x GC 460AH battery bank. For dry camping, recharging via alternator, gen or solar has to be considered. And the battery bank capacity is a factor.
Many campers are satisfied with the refer conversion and don’t make any additional equipment changes and rely on utility power, gen or driving/alternator.
Nov-04-2015 06:51 PM
You would be surprised at the number of people I have met in the last year who do NOT know what an inverter is. They are usually (but not always) in a fifth wheel and are running the generator to watch tv. I have stories...
Nov-04-2015 04:40 PM
Nov-04-2015 04:36 PM
pianotuna wrote:
Hi,
You do not know what make, model, or size of the converter, so you can not state a run time for the recharge via generator.
Personally, I'd opt to add some solar panels with a decent controller.dahkota wrote:
Because people typically drive for 4-6 hours and then park for about 72+ hours. The coach would need to be plugged in or the generator would need to be run fairly often. If the fridge uses 150A per day, the generator will need to be run at least 4 hours a day just to keep up, if parked in a dry camping situation.
Nov-04-2015 04:14 PM
Nov-04-2015 03:20 PM
Nov-04-2015 03:08 PM
Nov-04-2015 02:18 PM
Nov-04-2015 01:57 PM
nbargolf wrote:
After band aiding a norcold 1210 frig for several months we made the move to a Samsung 18 cu ft vs the 12 cu ft old one. you may ask the cost well it was less than putting a new cooling unit on the old frig, a no brainer. If your around the St Augustine, FL area Ocean Grove RV on Hwy 1 south of the city did a great job. It took them only 5-6 hours, one day in and out. We love it. :C
