RV service, how often.
GHOST1750
How often do you have your diesel motor home serviced. I'm getting ready for a 4,000 mile trip and had it serviced about 2,000 miles ago (last Dec). It is a 330 Cat with 57,000 miles on it. Normally I have it changed once a year. It is a 2003 National Tradewinds.
Just Don and a Chiuahua called Dulce
2003 39' Tradewinds LE
2002 Cavalier tow
Korean Veteran, USAF
FMCA F357981
CC4C
GOOD SAM
Life is a journey, not a destination !
13 REPLIES 13
ncrowley
It sounds like you are just talking about an oil change, which is usually done once per year unless you are putting on a lot of miles. But there is a lot more maintenance that should be done. You need to get the maintenance schedule for your engine and chassis and make sure all the periodic maintenance has been done.
Nancy
Newmar Northern Star
bluwtr49
My routine is:
Oil and lube every two years
Tranny every 4 years (Transynd)
Coolant (ELC) every 4 years
Both Hydraulic Tanks every 4 years.
So basically I'm doing something every year along with a fluid analysis.
Engine is a 505 Cat C-12 with 36 qts of oil.
Allison 4000 shallow sump
Dick
2002 43' DP Beaver Marquis Emerald Cat C-12 505 HP, 1600 Tq
2003 Jeep Grand Cherokee Overland ---toad
barmcd
Sounds like you are talking about an oil change--servicing a motor home involves more than changing the oil. You have oil, fuel filters, chassis and drive train lubrication, air filter, air dryer, transmission service, hydraulic fluid service, and others. They all have different intervals.
rgatijnet1
You didn't say anything about what has been done with the engine since last December. Has the coach just been sitting or have you exercised the engine during the last 8 months or so?
If it has been sitting this whole time, it may be a good idea to check to see if any moisture has accumulated in the crankcase that would necessitate an oil change.
If it has been used/exercised during those 8 months then you should be fine for a 4000 mile trip.
tinkerer
On a C7 Cat it depends on the size of the oil pan. The 19 quart pan requires more frequent oil changes. You instructions should tell you.
Kayteg1
oil test
My 1972 Prevost would allow 100,000 miles between oil changes if the test confirm quality.
lj2654
when the oil analysis says to......
2001 Beaver Contessa Naples 40
2012 Cadillac Srx
retired AirForce 1979-1992
accsys
Mandalay Parr wrote:
Once a year or 11,000 miles per CAT for mine.
+1
John & Doris
Doris and Robbies Blogs
2017 Cedar Creek Cottage 40 CCK
FMCA F380583, PA, Good Sams
Mandalay_Parr
Jerry Parr
Full-time
2005 Mandalay 40B
Cat C7 350, 4 Slides
Blue Ox, Brake Buddy
2004 CR-V Toad
jrparr@att.net
602-321-8141
K7OU - Amateur Radio
Kenwood Radios
ARRL, W5YI, & LARC VE
SKYWARN Weather Spotter
Trackrig
You've been putting about 3,500 miles a year on your MH. Once a year is plenty. If you were putting a lot more miles on it, do it at 10,000 miles. If there's a Speedco near a grocery store, let the DW do the grocery shopping while you get an oil and fuel filter change. I prefer to take my own filters as they don't always have exactly what I prefer, but I always have at least two spare sets with me. They can also do the generator.
Bill
Mr_Mark1
I have our Volvo D-13 serviced at 10,000 mile intervals.
They told me to go 15,000 miles but that just seems like too much. I can remember an interval of 10,000 miles better so that's easy for me.
The chassis needs to be lubed at 6,000 miles. I chose to go 5,000 miles which means, that every 5,000 miles I'll be in the shop to have a chassis lube and/or an oil/filter change at the 10,000 mile mark. At 30,000 miles, it's all good so far!
MM.
Mr.Mark
2021.5 Pleasure Way Plateau FL Class-B on the Sprinter Chassis
2018 Mini Cooper Hardtop Coupe, 2 dr., 6-speed manual
(SOLD) 2015 Prevost Liberty Coach, 45 ft, 500 hp Volvo
(SOLD) 2008 Monaco Dynasty, 42 ft, 425 hp Cummins
drwwicks
I would suggest what the manufacturer recommends. Cummins recommends annually or 15K on mileage for the ISL. I seriously doubt Cat would recommend a 6K change.
2007 Itasca Horizon 40FD
2012 Jeep Wrangler Sahara
2015 Harley Davidson FLHTKL
charwan
I would go with 6000 and 12 months which ever comes first. I worked for a big Co and we had 38 K vehicles and they went with 6 K or 6 months whichever came first. In doing that there I have changed oil with only 1K miles on oil.
N4FAP
