Water pump on and offf,,,
moon_lake
I have noticed that the water pump sporadically turns on and off when
no one is even using the water, and hasn't used it in days. Is this
normal? Or do I start looking for a leak under the rig?
Thanks.
12 REPLIES 12
msmith1199
moon.lake wrote:
Thanks for all your replies! This seems to be about every 5 to 10 minutes and I find it annoying,,, so I guess it time to start checking the system.
Also had the rig unplugged for a couple days and heard an occasional beep,went out to check the rig and it was both the carbon monoxide detectors,, not a full blown beeping sound, but a short occasional beep,, its not done this before when unplugged. Anything to worry about?
If it's every five to ten minutes then yes, something is wrong. Could it be one of your valves in the wrong position? In my plumbing compartment if I leave the valve that controls water from either city water or internal water in the wrong position when not hooked to city water, then my pump cycles every few seconds too. Check those first. If not that and you can't find water leaking anyplace (should be a noticeable leak with an every 5 to 10 second cycle) then it's probably just the bad pump.
2021 Nexus Viper 27V. Class B+
2019 Ford Ranger 4x4
Old-Biscuit
Low battery voltage
OR
expired detector.......check backside for date. 'Self life' for detectors is typically 5-7 years
moon_lake
Old-Biscuit
Pump cycling......lose of line pressure
Leak at fitting(s)
Leak thru check valve (pump internal one or city water connection one)
Leak thru low point drain valve(s)
Leak thru toilet water valve
Leak at faucet
Leak from Pressure Relief Valve
And just due to hot water side cooling off.
Rapid cycling (every few seconds) major leak
Occasional cycling (every few minutes) minor leak
Every once in awhile (hour-hours-days) very small leak
The real question is WHERE is leaking.
If NOT at a fitting etc. and just thru check valve......ignore/replace pump internal/add in-line on pump discharge line----if city water connection check valve......replace assembly OR screw a 3/4" PVC plug into connection.
wny_pat1
You might have a water pressure bladder tank, and it could be leaking off air pressure. If you have one, they are usually the same as you would find on a well water pump, and you can find new ones at Home Depot or Lowes. Don't know if the older Georgie Boy Cruise Master has them or not.
โ€œAll journeys have secret destinations of which the traveler is unaware.โ€
msmith1199
Once a day, once an hour? Okay what's the real rule? To the OP, mine only cycles about every 4 to 6 hours and then when it does it only runs for just a few seconds. It's done this since new. Is that normal? I have no idea. It doesn't bother me too much at this rate. As long as it's just water leaking back through the pump I doubt it will hurt anything and the only issue would be if it's bothering you too much. But the problem could also be caused my a small leak someplace in the system. So you do need to look around for a sign of a leak.
Clay_L
427435 wrote:
The check valves in the pump itself can leak down. Ours cycles every once in a while without any water usage. It has done that for years without any sign of an external leak in or under the MH. If it is only cycling infrequently (once per hour), I wouldn't worry about it.
Same here. At a rally several years ago a factory rep gave me a rebuild kit for the pump check valve but I haven't bothered to install it since the occasional burp doesn't really bother me.
Clay (WA5NMR), Lee (Wife), Katie & Kelli (cats) Salli (dog).
Fixed domicile after 1 year of snowbirding and eleven years Full Timing in a 2004 Winnebago Sightseer 35N, Workhorse chassis, Honda Accord toad
weathershak
X2
Full timing it since July 2012
427435
Mark
2000 Itasca Suncruiser 35U on a Ford chassis, 80,000 miles
2003 Ford Explorer toad with Ready Brake supplemental brakes,
Ready Brute tow bar, and Demco base plate.
vtbig
The pump runs because it is losing pressure somewhere inside your motorhome. You either have a leak in a waterline or maybe only a loose fitting.
Richard
2003 Safari Trek 3011
8.1 Workhorse/Allison
CT_WANDERER
The Pump will keep the pressure at a set point. I would only be concerned if it was cycling more than once a day. I know my will not cycle if no one uses water for a few days. If it cycles more than that I would start checking., it could even be leaking pass a check valve back to the tank. I am sure you will hear from others on where and what else to look for.
enblethen
Normal! Yes, in most rigs this will happen. It could be a small leak. Most likely it could be leaking back through the pump.
We normally turn the pump off when not in use.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
