When to check tire pressure. Hot or cold
Donna_and_Rob
First thing in the morning the front tires show 100psi about five miles later they show 110psi. Which should I go by? cold or hot.
I'm thinking hot.
2003 38ft Travel Supreme
350hp Cummins
15 REPLIES 15
ol_Bombero-JC
dkreuzen wrote:
Because I live in a hot climate my "COLD" temperature could easily be 95* degrees in the garage.
I found that I have to condensate 9 psi or when I travel to a colder area.....
Condensate? - :?
compensate? - :h
dkreuzen
While the answer of when to check the tire pressure is "COLD", the definition of "COLD" also needs to be explained. The definition of "COLD" is the condition where the tires have not been driven on for some time and their temperature is stabilized. However the actual temperature of a "COLD" tire needs to be taken into consideration. Because I live in a hot climate my "COLD" temperature could easily be 95* degrees in the garage. I found that I have to condensate 9 psi or when I travel to a colder area the tries end up low when they cool to say 55*. I use the following chart to determine my "COLD" pressure depending on the "COLD" tires temperature.
Pressure-Temperature chart
Dennis
2012 Monaco Knight 36PFT
2019 Jeep Grand Cherokee Overland
2005 Jeep Wrangler Unlimited Rubicon on 2007 16' Car Trailer
edm3rd
rk911 wrote:
I'm thinking hot.
cold. always cold.
AND check early am before sun is on the tires. Those big black tires can absorb a good amount of heat before you hit the road.
rk911
I'm thinking hot.
cold. always cold.
Rich
Ham Radio, Sport Pilot, Retired 9-1-1 Call Center Administrator
_________________________________
2016 Itasca Suncruiser 38Q
'46 Willys CJ2A
'23 Jeep Wrangler JL
'10 Jeep Liberty KK
& MaggieThe Wonder Beagle
wallynm
Tire Pressure
My experience.
Air pressure Air Pressure, Temperature Fluctuations
Have a Diesel Engine Diesel RV Club
Have a Freightliner FCOC Web Page
Living on the memories now
EX 02 DSDP 3567
EX 99 Coachmen
EX 86 Georgie Boy
EX 75 Winnie
EX 72 Sightseer
EX 68 Brave
THOSE THAT DO NOT KNOW HISTORY ARE DOOMED TO REPEAT IT
Mr_Mark1
It's best to weigh your motorhome to find the correct pressures. And, COLD is the time that you should check pressures. Your tires might even go up to 130 on a hot day.
On our Dynasty, our 'weighted' correct pressure is 110 (front tires). I keep 120 which is the max cold pressure. When it falls to 110 after 4 or 5 months, then I fill them back up to 120.
The drive and tag I keep at 105 but will fill them up when they fall to 95. The correct is about 90 for drive and 75 for tags. I keep them over inflated just for safety as the max cold is 120.
MM.
Mr.Mark
2021.5 Pleasure Way Plateau FL Class-B on the Sprinter Chassis
2018 Mini Cooper Hardtop Coupe, 2 dr., 6-speed manual
(SOLD) 2015 Prevost Liberty Coach, 45 ft, 500 hp Volvo
(SOLD) 2008 Monaco Dynasty, 42 ft, 425 hp Cummins
ddndoug
Cold
2009 Four Winds Hurricane 33T
F53 Ford Chassis w/Triton V-10
J-Rooster
ScottG wrote:
Cold. The tires are designed to heat up and increase in pressure.
This is correct!
Grandpere
brirene wrote:
darsben wrote:
THIS is the correct answer
Yup, x3.
X4
Berniece & Russell Johnson
Lil'Bit, a Netherland Dwarf Rabbit
1987 Southwind
1995 Ford F150 Supercab
Life in the fast lane? No thanks, we will stop and smell the flowers at every opportuity
TucsonJim
This short article should answer many of your questions. It's very informative.
Tire pressure: When and How to set
2016 Ford F350 Turbo Diesel SRW 4x4
2017 Grand Design Reflection 297RSTS
2013 Ford F350 Turbo Diesel SRW 4x4 (Destroyed by fire - 8/29/16)
2014 Grand Design Reflection 337RLS (Destroyed by fire - 8/29/16)
brirene
Yup, x3.
Jayco Designer 30 RKS Medallion pkg, Trail Air pin
'05 F350 6.0 PSD CC 4x4 DRW LB B&W Companion, Edge Insight
โ€œCertainly, travel is more than the seeing of sights; it is a change that goes on, deep and permanent, in the ideas of living." Miriam Beard
Old-Biscuit
Read the information on the sidewall of your tires.........
darsben
Traveling with my best friend my wife!
bshpilot
Install a TST Tire Pressure & Temperature Monitor and you'll never have to worry about or checking the pressures again (just turn on the monitor & you're done) !
If the temperature rises to dangerous levels (165* +) or if the pressure drops by x percentage or pressure the monitor alarm will sound to notify you.
Install sensors on your toad or trailer too & you'll know the pressure & temp while you tow !
Don R.
'04 42' Haulmark Motor Coach - 450hp/1650tq / 12 spd SmartShift
'12 Jeep Wrangler Sport (manual trans)
'17 Platinum F350 (6.7L, SRW, CC, Long bed, 4x4)
