Windshield wiper replacement
two_travelers
I need to replace the wipers on our coach. They are 31.5" so I assume 32". Seems the auto stores don't carry that size- 28"max and on line, 32" blades are more expensive than gold. Where is a good place to buy them? Are there alternatives to the 32" that work. Thanks to all whoe share their knowledge.
30 REPLIES 30
WILDEBILL308
I had this thread in mind yesterday when I was at the new REV Group repair facility in Alvarado Texas. I had them do a search on my coach and see what the original equipment wiper blade was. I had 28" on it(the way I got it) but they said it shipped with 26" blades. Go figure I would have said 32" or more.
Bill
2008 Newmar Mountain Aire
450 HP CUMMINS ISM
ALLISON 4000 MH TRANSMISSION
TOWING 2014 HONDA CRV With Blue Ox tow bar
A man who carries a cat by the tail learns something he can learn in no other way.
-Mark Twain
JoeH
JC2 wrote:
Our Newmar DS has 32 inch wiper blades which can sometimes be hard to find from outside sources at a "reasonable" price. We found both 28 & 32 inch refills at our friendly Oreilly Auto Parts and a good price. The 28 size cleans as much glass area as the 32 inch was duing.
I had a wiper disintegrate while in Utah, stopped at a O'rielly and they had them (32") there the next day
Joe
2013 Dutch Star 4338- all electric
Toad is 2015 F-150 with bikes,kayaks and Harley aboard
subtroll
Our coach came with 26" blades. Last replaced them with Rainex 28" blades as obviously the windshield is much larger. Unfortunately the slightly longer blades don't clear as well as the original shorter blades...the difference is very clear.
I'm going back to the shorter blades.
2004 National Tropi-cal Sterling 396
2003 Jeep Liberty
J-Rooster
Happened to me one year coming back from Arizona. I pulled into a Chevrolet Dealership in Corning, California. They replaced my blades with new ones for $15.00 plus tax I was back on the road in about 10 minutes.
Campinghoss
http://www.dieselequipment.com/index.php/shop/
This is the best place I have found for good quality wipers at a fair price.
Camping Hoss
2017 Open Range 3X 388RKS
MorRyde IS with disc brakes
2017 F-350 6.7 with hips 8'bed
Lucie our fur baby
Lucky 9/15/2007 - 1/30/2023
falconbrother
I just replaced the blades only last night. I know this is no help but, I bought some blades only years ago and found them while looking for something else. Sure wish you could still do that. The blades now cost like, $50.00 for a set.
CharlesinGA
I found a lot of odd size blades (really short or really long) in an Ollie's store (closeouts and overstocks chain kinda like Big Lots but nicer) They didn't have any size I could use, as I only have common sizes, but they had some crazy long ones, and stupid short ones (but not for rear windows).
Charles
'03 Ram 2500 CTD, 5.9HO six speed, PacBrake Exh Brake, std cab, long bed, Leer top and 2008 Bigfoot 25B21RB.. previously (both gone) 2008 Thor/Dutchman Freedom Spirit 180 & 2007 Winnebago View 23H Motorhome.
want-a-be
JC2 wrote:
want-a-be wrote:
We had the same problem, called the manufacture of our RV and got them cheaper then else where and the right size.
Good Luck
That has to be a rarity as most manufactures usually are quite proud of their "stuff". :B
My blades where 33 inch and hard to find. Called Tiffin and they said they where special made for Tiffin! Price was $17 and some change. They are J hook.
Good Luck
mtrumpet
That's interesting. My DS also uses the 32" blades. I currently have a new set of 32" to put on, but I may try the 28" should I ever have a hard time finding 32" blades. But first, I need to change out my wiper arm assemblies with new ones. The current arms are pretty well shot.
Mark & Cherie
2002 Newmar Dutch Star DP 3872, Cummins 350 ISC, Spartan Chassis
JC2
2010 Newmar Dutch Aire 4304,Cummins ISL 425hp,Spartan MM Chassis,2013 Chev Equinox AWD Towed,Ready Brute Elite TowBar/Brake,FMCA #402879,SKP#120487
JC2
Good Luck
hardint
I agree on the J hook adapters,forgot where I got mine but below is the Bosch part
http://www.ebay.com/itm/BOSCH-Windshield-Wiper-Arm-Adapter-Converter-Kit-3-392-390-298-/271602492411
Lancslad
Use 28's...... and RainX
2011 FR Georgetown 337DS
2003 Dodge Dakota Towed
Moondaddy
Just finished that job. Took entire arm and blade to supply store.
Only one blade would work for 05 Monaco, no 31 inch but ordered 28 inch.
Has a saddle/bolt with adjustable angle on arm assembly. Had to replace one arm as the adjustment teeth were stripped. Glad I took the entire assembly, replaced both arms and complete wiper blade assembly and put another set in lower bay. I looked at a large truck stop on I-70, 28 inch is as long as they stock and no refills.
