Many years ago I started smoking with the Brinkman charcoal water smoker and loved it. But I also got tired of feeding charcoal, so I bought the electric version. Worked great.
When I started full timing 2 years ago I gave it away (didn't think I had the room) and bought a small Weber Q propane grill. It's wonderful but you just don't get the taste. So I bought a small Weber charcoal grill. Works great but I can't smoke on it. Then I saw that a few people in the CG where I overwintered had pellet grills, so I went and talked to them. They loved them. One guy said it even improved his marriage.
So bought the Green Mountain Grills Davey Crockett pellet grill. It's legs fold up to make a handle (and decrease the overall size). It runs on 110v or 12v and they even include alligator clips so you can clip onto a free standing battery ! The temp can be adjusted in 5 degree increments, has a digital readout, and there is even a WiFi model you can control using your phone. They also include a meat probe that's linked to the digital readout so you can monitor the temp of whatever you're cooking. This baby is seriously cool. Yup, I really like the thing.
Temp can be adjusted from about 180 to about 500 degrees and the best part is that, once set, it holds the temp really well. And anything cooked over wood tastes great.
The negatives:
- You need electricity to make them work. They need it to run the augur, fan, and heat control system.
- It's difficult to get sear marks on a steak because you cook over indirect heat.
- I don't think that I get the real deep smoky flavor that I got from my water smoker. But I am just getting used to it - there are probably some things I can do to get a smokier taste. And I might just put a pan of water on the grill too.
The people I talked to use them a couple times every week. I think it's because they are so versatile. You can cook low and slow, or start out at a low smoke temp and then increase the temp to finish cooking, or just set it at 350 and basically cook over a wood fire. But the best thing is you can truly set it and forget it. You could smoke a pork butt for hours and monitor internal temp via your phone - adjust the cooking temp up or down, or set to the lowest temp when done, in case you're driving home from an errand and are running late.
I carry three kinds of wood - hickory, mesquite, and a mix - in 3 each, 5 gallon containers with good screw down lids that have gaskets (to keep the moisture at bay).
You might call around to your area BBQ stores and see if they ever have a cooking demo so you can taste food that's cooked over a pellet grill.
I also suggest that you check out pelletheads.com
Yes, I am carrying 3 grills now. But the pellet grill is easily my favorite. I am a convert.
Tim
