โMar-23-2016 08:53 AM
โMar-27-2016 08:26 AM
bobwalter wrote:
Glad it worked.... Now, use plenty of water and don't dump until your black tank is almost full. Do not leavi ti hooked to a sewer with the valve open. Keep it closed and only open it when tank is near full. Oh yea, did I say to USE LOTS OF WATER!!! Water makes for a good dump. Lack of water causes constipation;) That not good for you or for your RV.
โMar-27-2016 08:25 AM
nomad.297 wrote:
Go on your roof and put a Drain King on the vent for your black tank. It will build up enough pressure to force the stoppage out of the drain. This won't work for your gray tank.
Edit: It will work for your gray tank if you know how to cap off your shower and sink drains. I'm a plumber, so I know I could do it.
Bruce
โMar-27-2016 07:20 AM
โMar-26-2016 04:16 AM
Bruce
Good way to blow the grommet out that some mfgs use to seal toilet drain line and vent line into top of waste tank. Might work OK if those lines going into top of tank are glued but those that use grommets are just friction seal. (same with grey tanks)
Could get real messy plus labor intensive to reinstall drain/vent lines back into top of tanks
โMar-25-2016 10:53 PM
Bruce
โMar-23-2016 05:48 PM
โMar-23-2016 03:50 PM
โMar-23-2016 03:27 PM
bobwalter wrote:
Get the clear plastic elbow with the garden hose connection. Put a cap on the end, hook up the garden hose, open one sewer valve and turn on the garden hose. This should clear the clog. Close the valve and remove cap with a bucket underneath. attach sewer hose and dump...... Use garden hose as needed to break up any more clogs. Do both tanks the same way. GOOD LUCK!!!!!!!
โMar-23-2016 03:25 PM
โMar-23-2016 02:13 PM
โMar-23-2016 12:35 PM
2012Coleman wrote:
Hope everything comes out allright...
โMar-23-2016 12:34 PM
โMar-23-2016 12:23 PM
