โMar-23-2014 01:44 PM
โApr-08-2014 10:21 PM
โApr-08-2014 07:31 PM
โApr-08-2014 07:02 PM
Ron Gratz wrote:3LittleDucks wrote:Your friends need to go through a process similar to the following:
I'm helping a friend trailer shop, they will be towing with a F150 4x2, rated at 9600lbs. Will soon be a family of 5.
They're looking at 25-26' trailers, dry around 4500, gvwr around 6500. Too much?
1) Estimate how much the TT will weigh when loaded for camping.
For example, a TT which is 4500# "dry" might have a loaded weight of 5500#.
2) Estimate the TT's loaded tongue weight which should be around 13% of the TT's loaded weight.
For example, a 5500# TT might have a TW of about 700#.
When using a properly sized and properly adjusted WDH, the vertical load transferred to the TV will be equal to about 75-85% of TW, depending on how much load gets transferred to the TT's axles.
Lets assume the TT-induced load is 550#.
3) Look at the TIRE AND LOADING INFORMATION sticker on the driver's door edge or pillar.
Find the maximum allowable weight for Occupants and Cargo.
Subtract the estimated TT-induced load from the TV's max allowable payload.
The remainder is the amount of payload capacity available for weight of occupants, items added to TV after delivery, cargo carried in/on TV, plus about 100# for the WDH.
4) Your friends will have to decide if the remaining payload capacity is great enough to meet their needs.
Ron
โApr-05-2014 04:02 PM
โApr-05-2014 10:22 AM
โMar-24-2014 10:26 AM
โMar-24-2014 06:47 AM
Old Days wrote:
The reason I say that, my TC loaded weighs about 1800 pounds and when I pull my 2000 pound boat my half ton truck struggles climbing the steep hills by my house. My next truck will be a GMC 2500.
โMar-24-2014 06:05 AM
Drew_K wrote:
Forget about the 9600 pound tow rating - almost meaningless. Have them check the payload capacity and check that against their estimated RV tongue weight and what they expect to carry in the vehicle.
I used to have an F150 with Ecoboost and towed 5k with it - no problem at all. If I went above 5K, I'd use a WDH. But again, check the payload numbers - that's the real limiting factor.
โMar-23-2014 07:00 PM
โMar-23-2014 05:24 PM
โMar-23-2014 04:47 PM
โMar-23-2014 03:33 PM
โMar-23-2014 03:32 PM
pappcam wrote:
A 6500 GVRW trailer is a good match for a half-ton unless the half-ton has no towing package or a standard V6.
โMar-23-2014 03:29 PM
