Chaining axle to frame?
path1
Doing some research on brakes. Saw this pic in old posting. Never seen that before. I assume in event of broken spring or axle or U bolts?
http://www.rv.net/forum/index.cfm/fuseaction/thread/tid/26404929/print/true.cfm
2003 Majestic 23P... Northwest travel machine
2013 Arctic Fox 25W... Wife "doll house" for longer snowbird trips
2001 "The Mighty Dodge"... tow vehicle for "doll house"
19 REPLIES 19
leeper
Old-Biscuit wrote:
Looks like chain is to limit downward movement (unloaded) to prevent brake wires from being pulled/broken
Also looks like someone wanted to have something to fasten the wire to. Strange set up!
myredracer
It looks like he added a bump stop to the underside of the frame. Between that and the frame, not much travel distance and something will break.
If you read the link to the thread, it's a utility trailer. Bump stop was added so that when heavy loads are in the trailer, the axle won't rest on the frame. Too little trailer and needs a 1 ton truck and maybe LT tires...
Rvpapa
One probable reason is if you were to load two Harleys on a soft sprung trailer. When the first one is run up and on, the trailer is going to be really unstable and a real #@%^ to load the second. Chaining as in the picture makes for a more stable platform.
Art.
Oaklevel
I don't see any broken spring leaves that's how they were made. ๐Ÿ™‚ Too smooth the be a brake anyway.....
wilber1
I can see the point about preventing the wires being snagged by debris but other than that, I see no purpose to it.
"Never trust a man who has not a single redeeming vice" WSC
2011 RAM 3500 SRW
2015 Grand Design Reflection 303RLS
cpaulsen
Have done this a couple of times on utility trailers when a spring broke. Took off the tire and wheel and chained it up.
cpaulsen
jfkmk
B.O. Plenty wrote:
Anyone notice the two broken/missing spring leafs?
B.O.
Looks like they were made that way. The shortest leaf extends just beyond the axle on the other side as well.
bucky
Yes, you. Good catch.
Puma 30RKSS
B_O__Plenty
B.O.
Former Ram/Cummins owner
2015 Silverado 3500 D/A DRW
Yup I'm a fanboy!
2016 Cedar Creek 36CKTS
Lynnmor
TrickyRicky wrote:
This appears to be a single axle trailer maybe not a camping trailer by the looks of the frame. Some box and or utility type trailers are hauled empty at times and this arrangement will take the bounce out of the unit when towing empty.
I thought too that it is not a travel trailer. My thought is that he will use it off road and he is trying to keep the wires from being ripped off by sagebrush or whatever.
path1
Op here...
Think I found the post relating to chains.
http://www.rv.net/forum/index.cfm/fuseaction/thread/tid/25541842/print/true.cfm
Batman99 if your watching. How did this idea work out over time?
TrickyRicky
2008 Newmar Torry Pine
2013 F350 Platinum, Pull Rite Superglide
A Cocker Spaniel "Tucker" a Cavalier King Charles "Lilly
and us Elaine & Rick
time2roll
Not a good idea IMO.
Better to just jack the trailer by the frame to determine the max travel and provide wire slack accordingly.
TrickyRicky
Could possibly be a form of sway control to keep the unit from tipping from side to side.
