โJun-20-2016 01:18 PM
โJun-22-2017 08:36 AM
โJun-22-2017 07:16 AM
hbillsmith wrote:
You can add an extended run tank using the Pinellas kit and a standard Yamaha connector outboard marine gas tank. The built in tank is 1.6 gallons good for 4 or 5 hours of A/C. I use a 6 gal. External tank that I share with my outboard. With the external tanks you can swap without worry about spilling gas on a hot genny and causing fire.
โJun-22-2017 07:04 AM
Sandia Man wrote:
We have been 6 hours using our AC but turned it off before generator could run dry. There are variables involved making the exact amount of time hard to pinpoint, we did have converter on and were using tv and satellite but fridge and water heater were on propane. In no way does our Dometic 13.5K AC unit max out our Champion 3100 watt genny, under the above scenario we were camping at over 7K elevation and genny was in eco-mode the whole time never missing a beat.
โJun-22-2017 06:50 AM
MrWizard wrote:
LP has less Btus of energy per gallon than gasoline ,
It will always use more LP than gas
But if you reverse the test, and use LP first, i think it will use a little bit less lp and a little more gas
โJun-21-2017 04:54 PM
โJun-21-2017 04:22 PM
โJun-21-2017 03:40 PM
โJun-20-2017 04:45 PM
Acdii wrote:
I really like the 3100 I have, the 75531i. It is very quiet even under load. If I can convert it to LP, that would be great, but haven't found a conversion kit yet.
โJun-20-2017 04:02 PM
โJun-20-2017 03:16 PM
Mel B. wrote:
I just ordered yesterday a Champion 3400 watt inverter with remote start. I had a dual fuel connection added for $145 and a hour meter installed for free. You can't get the dual fuel option with the remote start without doing it this way. I'm hoping That the propane runs my 13500 A/C if it does I don't think I'll ever use the gasoline feature, as we have a great solar system that runs everything else. And propane so much easier and cleaner. This cost me a little over $1200 I'll have here next week I'll let you know
Mel
โJun-17-2017 06:24 PM
โJun-17-2017 04:36 PM
โJun-17-2017 02:15 PM
โJun-10-2017 07:48 PM
โJun-10-2017 07:09 PM
Unyalli wrote:
I know the OP already has a gas only champ. I sold my twin 2000's with parallel kit and got one of the new 3400 watt dual fuel inverter generators. Removing the regulator from the propane motor and plumbing RV propane quick connect fittings you can connect to the outside grill quick connect and have endless extended run via the RV propane auto switch over.
- Jeff
